I have the older black model.. it has worked well. The only time I have seen an EWS get out of sync with the ECM is when a customer tried putting a different EWS in the car and tryed to start the car.. I have a 3 in 1 tool like this
BMW Dash Scanner 3 in 1 Free Shipping
it lets you scan for codes and also can sync the EWS with the ECM... The poor car had been thru a couple of so called mechanics.. The keys they had were not rolling correctly and was causing problems, it would start 4 times and then the key would go out of limits on the roll and car wouldn't start... and this was with a brand new EWS from the dealer.. I read the old EWS and burned the data to a key and put EWS in the car, synce EWS to the ECM and tried to start car... it wouldn't start... cranked and cranked, but no start.. checked for errors.. and found none.. Put gas pedal to the floor and cranked.. The car started like a 1950s tractor... They had flooded the poor thing so bad it was crazy... After about ten minutes it started running ok again.. That poor car. As for the multi tool, when it pulls the key data, it gives you all ten keys data.. I chose number four because that is what I usually pick on an EWS car that hasn't had any extra keys made for it... On an EWS it usually only has 3 keys built in, if you want more then you build them into the bin file and rewrite that to the EWS, on the CAS it seemed to have all the 10 spots filled with data... so I just picked one and wrote the data to the key.. It worked fine...
Take care,
Tim
PS I made a vid about the AK90 a year or two ago.. feel free to check it out...
Screencast-O-Matic - Record screen capture video instantly for free!
