Results 1 to 8 of 8
Thread: openbox s11
    Jan 2011
    Default openbox s11
    my openbox s11 keeps rebooting every time i change chanel please someone help
    Top Poster fazz69's Avatar
    Feb 2009
    Somewhere
    Quote Originally Posted by jedi74 View Post
    whats firmware are you using..
    Jan 2011
    hi im using skybox s10 firmware
    Feb 2009
    Somewhere
    I have just added this image to site.. download this s11 image and see if it helps.. im using this and its working fine.
    Openbox s11 firmware - Downloads - Digital Kaos
    Jan 2011
    hi thanks will try will let you know the outcome
    Jan 2011
    hi mate tried that butt still rebooting
    Apr 2012
    Quick check is to disconnect Sat Cable and reboot if it stays up without rebooting defo PSU problem.
    Have a look at the Capacitors on the PSU module see if tops are blown, replacement PSU's are available on Fleabay.
    Hadron's Avatar
    Nov 2012
    E. London
    The usual suspects on the PSU board are C11 (1000uF 10v) and C15 (470uF 10v).
    Even if the tops are only slightly bulging then they need changing.
