for me this file is original and good!
OK but I need help with FAP OFF
I try switch one byte solution but no succes...
why?
it is mean samething can be wrong!
I try 3-4 solution but allways reserve program... to 3.000 RPM...
with volta no dtc but steel in limp home...
PPS dtc is about FAP "diferential preisure bla bla"
All OK with combination volta and one byte and unplug sensor diferential preisure...
After 4 days and after 200-300 km car is back and car is again in the reserve program...
Anyone try to help?
first upload flash file not MPC! and your dtc that you have in the car if you want to do this job once and right.
No flash memory in this EDC16C34... ecu 0 281 011 633 only mpc
edc16c34 org 407 2007 1.6hdi fap_All
edc16c34 org 407 2007 1.6hdi fap_EEprom
edc16c34 org 407 2007 1.6hdi fap_Flash
this is three files you should get if you use bdm to read edc16c34.i cant see mcp in them.
With BDM only can read file in first post and eeprom... no external flash memory.
All data is in the MPC562.
Nocni (9th May, 2014)
Thanks... I try tomorrow morning and report here but see file and is very similar with my first try... switch one byte in 001EE710...
@immokill,
For now car work good... I add egr off in your file and back car to testing couple days... will see what happend but thanks for help x10...
