does anyone know here a tool that can calculate the 4 digit security code from opel based on VIN or anything else?
You need radio or key code? But none of that from VIN, some tools some equipment and some knowledge and you done it.
i need the key code... i have a 2006 opel astra, 1.7DTH, i have the underhood electric module from another car and when it was removed they didn't reset it, so now i have to code it on my car but i can't because i don't know the security code. what kind tools are you reffering?i might have the equip needed...
You need opel login reader from codecard, i do not have it , but my friend does.
here
OPEL login reader from motor hybrid ECU.
I am , interested for that, i have serial op-com , but hi can not do that
any tutorials using op-com will be very usefull...i have op-com firmware version 1.20 and works fine on everything i tried and know i have a component from another car and i need to reset it but i don't have the code for it ...
op-com does NOT retrieve the security code from vehicles
"Originally Posted by vevepatronu
i need the key code"
It will retrieve key code info but you need to have security code to access that information
you will have to get both car passes from vx.
Joe
hi you can get the carpass from vuxhall for the car you have you will need a v5 (log book ) to aply for the pass
a good locksmith with an eeprom reader can do thistoo but its cheaper to have it scanned and pm the fault code .can you suply more detail of the problem and any other relevant stuff ? ..
using vaux com (i think its the same as op com) go to body then immobiliser (might be another section within body). select programming and i think there is a button which says retrieve code. if i am right this should retrive the code. havent had the oppertunity to try this my self but i saw the button.
hope this help
veve you can read security code in the immobox if you have tms370 programmer remove mcu and read it in the programmer
