did you open ecu from the bottom side
Does any one have a solution for this system? No separate eprom inside just a freescale mcu mask 2m27v. What programmers will read this assuming its not secured or someone knows the security bytes.
I've removed the circuit board from the case to get a good look at both sides. The freescale mcu is on the top were I would of expected to find an eprom. On the underside there is another chip "Keihin KT2012SA 326103" Struggling to find any info on this chip though.
This is the honda smart key for bikes, correct?
photo 1.JPGphoto 2.JPGHONDAHISSDASH.rar
Nope its still a HISS system with a normal key switch ignition. It has a VDO dash with 24c04 eprom if thats a clue to anyone.
My bad a93s66 eprom in the ecu. I didnt dig far enough its tight up against the back of the plug. All sorted now.
Can you add foto with localization of eprom in this ECU.
38770-100320ncf750.jpgSorry I didn't get a picture with the case open. The location is marked on the attached image.
BAL LOCKS (1st August, 2021)
memory_93x66
keys_79x36 x2
A topic that interests me
kyawzin (9th May, 2020)
Hi working on a NC750X 2017 the ECU looks the same as your. Had a look at the location you suggested but no chip, have you done any others like this, where it has been found in an alternative location?KEIHIN_38870-MKA-R82-3RU.jpg
hey thanks for the reply but sorry not sure what you are saying here? is eeprom locate a website? as tried to search and nothing came up
Thanks for feed back did a wider search and found a similar ecu, and another post by Cromwe11. For other newbies not familiar with these pages or non regular users. Hope this helps someone else also.Honda NC700 ECU eeprom location
I have eeprom from this ecu.
Did you found the keys location pls?
eeprom file in attachment
THX
