Results 1 to 13 of 13
    Top Poster poppyjack's Avatar
    Jul 2011
    Leicestershire
    Default configure my cable tuner help!
    Just got a cable dreambox800se, I've tried to do a scan with no luck, just keeps saying failed, configure your tuner, the tuner is enabled.
    I've gone to cable scan to these settings below, but not sure what to put in.
    Tuner - enabled
    Frequency
    Modulation
    Network id
    Use official channel numbers
    HD list
    Ive put my cables.xml from my dm500c - etc/tuxbox onto the box biut still no luck.
    Any help would be great.
    digicon's Avatar
    you will need the Network ID and the frequency for a scan as not all areas have the same ID/Frequency
    how do we find these for the birmingham area thanks
    plasterer's Avatar
    Jun 2008
    Mersyside
    Smirnoff may be able to help you with Birmingham settings .....................Paul
    PAUL
    digicon's Avatar
    you could always try a brute force scan which should work
    home
    hi I just got a dm 800c and im lost can anyone give me some help I cant even set up the tuner
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Mar 2009
    Quote Originally Posted by poppyjack View Post
    Tuner - enabled
    Frequency
    Modulation
    Network id
    HD list
    Hi there, im in exactly the same situation. Im in Brum too and have flashed Smirnoffs image onto my Dreambox. I was hoping that it would pick up some channels but no luck at all. I get the same error message as you ' tuner failed'.
    I'd love to know the above settings too if anyone has them.
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    if your in birmingham should be ok , anyway change tuner settings to this (use right arrow button to change) no need for netid , then save and full scan
    if that dont work u have a tuner setting fault
    Mar 2009
    Quote Originally Posted by smirnoff_rules View Post
    didnt work unfortunatley. not sure what else it might be. Would you know if VM disconnect households from the cabinet? I havent been on cable for about 5 years now, but all my cabling is still intact in the house. Is there any other way of checking if im still connected?
    Thx for the help so far BTW.
    Sydk
    Mar 2008
    birmingham
    if u havnt not bbc1 its not connected
    Mar 2009
    Smile
    You were right, i got myself connected, and now have the basic freeview channels.
    Thanks for the help Smirnoff! You gotta love forums
  13. #13
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    Thumbs up
    on dreambox on provider select cable uk and scan should pick up all channels.
    sorted I think !!!!!!!!!!!!!
