Results 1 to 11 of 11
    Garage
    Default tms370c036 problem with upa
    Is it possible to read this tms with upa usb v1,1.
    I connect like it say in manual but only read 00
    upa say that read success but only 00.
    I need to read this tms from twingo ecu MM IAW 6R.30.
    How to connect this on upa usb adapter for tms if upa can read this tms.
    Member tuning73's Avatar
    italy
    Law perfectly with the micro adapter has uupa you have to build the schema into the folder and colleagues adapter tms with what the built
    italy
    here and adapter pattern to create works perfect
    Garage
    I have connect like in this picture and just read 00
    Upa say that connection are ok but only read 00 when try read more thimes show something but cannot read.
    I try verify once say ok once error.
    Do you have dump for upa v1.2 maybe my upa dont work.
    I buy this upa dealer say that is v1.2 but i need to change eprom dump bicouse is not work with soft v1.2.
    Its read eprom and motorola witouth problem but maybe have problem with this tms
    Thanx
    Garage
    Is someone have some tip hov to read this tms with upa usb?
    Garage
    I solve this read with upa.
    Thanx all for answer
    Jun 2009
    porto portugal
    how you read it with UPA?
    regards
    Mar 2014
    Quote Originally Posted by jjrp255630 View Post
    regards
    You need to read in adapter, can read it in-circuit too but need to lift some pin if I remember 6 and 58, , so better solution is read on adapter.
    Jun 2009
    porto portugal
    hi, i make a adapter like in PDF but only reads 000, need to put a oscilator?
    regards
    Apr 2014
    Spain
    This is my invention works perfect.
  11. The Following 2 Users Say Thank You to danielif For This Useful Post:
    firefox18 (15th October, 2018), kitnoos2002 (24th May, 2017)
  12. #11
    didi_du_93000's Avatar
    France Paris
    I use xprog m or orangre5
