Results 1 to 8 of 8
    May 2014
    Default Shran 1.9 tdi injectors swap
    Hi to everyone, I need your help with vw sharan 115 bhp with upgrated injectors from 130 ASZ anyone can help me to make some changes in soft plssss
    May 2014
    I got very high bips and huge fuel consumption
    any help?
    Germany
    Correct the opening-current! There is a Line for that with one axis (Battery-Voltage). The ASZ-Injectors are different from the Coils and the inner mechanics and therefor you need to copy the opening-Current-Line from an ASZ-File to your file! Even the BIP-Maps are different, so copy these ones too will help you!
    Senior Member Diagnosticated's Avatar
    Mar 2011
    This is a big task. Bip maps, SOI and duration all need changing to map new injectors. You need to compare your file with one that matches the injectors you have.
    May 2014
    1 step: soi copied,can you check it for me please? car starts, I tried to change 541F2 10x1 map - 6% = bip went up 127, +6 % bip reduced from 100 to 80
    May 2014
    bip sorted but still high fuel consumption
    nobody swapped pd injectors ???????????????
    Sep 2010
    need to change soi, duration, bip: 10x1, 8x10, 10x6 maps
  8. The Following User Says Thank You to proel For This Useful Post:
    yezoo (13th May, 2014)
    I copied the maps duration, in your original file
  10. The Following User Says Thank You to pinotec For This Useful Post:
