Results 1 to 11 of 11
    europe
    Default Crafter edc16cp34
    Hi can someone check these file is it OK and are the DPF removed from damp
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Yes it is switch solution on 1D4378
    Here to HELP!
  3. The Following User Says Thank You to immokill For This Useful Post:
    VDO (10th May, 2014)
    DK Veteran velindro's Avatar
    Portugal
    Default crafter
    i think with this file you will get in trouble,because timer still on,sooner or latter you will see!
    try this one,timer and pressure switch off!
  5. The Following 2 Users Say Thank You to velindro For This Useful Post:
    masterb (11th May, 2014), VDO (10th May, 2014)
  6. #4
    europe
    With first dump I make also reset of ash with diagnostic on option for new filter add ,@velindro at the end maybe I put your damp on ecu to be sure for right job done thanks mate
    Portugal
    Quote Originally Posted by VDO View Post
    your pm box is full
    cant send anithyng
  8. #6
    europe
    No it is not full I got from you PM on 10th May ,Thanks again
  9. #7
    europe
    Hi i have these error now P1040 when I start engine work for 3 sec then goes off if i start engine and press and release throttle pedal above 1500rpm then stay to work normal what can be problem?
  10. #8
    Portugal
    what file did you put in car?
    switch solution?
  11. #9
    These ecu must be BDM ed always and do just 2 switches solution. all sensors conected and working!
  12. #10
    Nov 2012
    smartville in front of a OBDplug
    they also work obd
    but not all can been read if ecu programmed in 2011 then you can't read or write obd because it's looked flash enable is off
  13. #11
    europe
    I read it with obd but when i try to write it crash on 29% and brick the ecu then I must to to read-write with BDM but i still have problem with error on both files switch solution and yours @velindro
