I read using OBD with galletto then when I went to write the modified file it said write BDM once then it wrote file and car would not start.
I would BDM if I was u. My car was a focus ST 3
what about kess v2?
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
make bdm....
i know mate but i wanna know a tool that does these via obd
CMD original does I think
BDM first yeah. don t play with it. after taht u can read write via OBD.
Opening these ECUs is v difficult they are VERy glued. I was never able to reach the bosch pads on the other side of the ecu so i always use the first side normal BDm pads. Heres my video
https://www.youtube.com/watch?v=JohHgppU-4A
Optician, ByteShooter should that can do by obd
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
FGtech will not write every software version. I know as i tune a lot of these. Early software versions yes, but not the later ones.
Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
