Does this have an aftermarket radio fitted if so unplug it and try. radio is connected to the eobd plug and after market radios mess this up. see rostech for the issue Ross-Tech: VCDS: Afterrmarket Radio Problem
'99 vw bora 1.9 tdi
ecu: 038 906 012 K
0 281 010 111
read ecu by obd with mpps. saved original dump. flashed moded dump, all flashing goes ok, after, car dont start, no communication with ecu at all... cant communicate any diagnostic tool, mpps. tried on the bench, same. desolder am29f400bt put on willem programmer, can read/verify, but cant erase and flash ori dump back. after erasing it says error erasing.
Any ideas how to flash ori dump back and make ecu alive again?
Don't Forget Button
Lexas (13th May, 2014)
change eeprom............ may be was damaged
Winols,Swiftec,CMD,Alientech Kessv2/Ktag/Powergate,Mpps
r54-tunedfiles.com
change 29f400
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Lexas (15th May, 2014)
I thing all with the 29f400 is fine but the willem programmer is really unstable sh.t i have 2 of them all of the failed me most of the time , same like your situation with a lot of chips .
After purchasing new programmer witch is little expensive i don't have any more trublles with any chip .
You can try with new 29f400 of flash it on boot mode up boot pin on 29f400 and make it on the bench and flash it .
If you need i can upload the image how you can make it . Or in google you can fined edc15v/p/vm boot mode .
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
Just make recovery in recovery mode on the bench with mpps
Don't Forget Button
you have no com.with ecu because flash is fu...,what you should try first if something happens like that is try to write back ori file,but dont press ecu id just type ori file and write ecu. this will over write your flash and all should be fine.
depend wich version of mpps are you using........... you have boot mode for edc15
r54-tunedfiles.com
