Do you have try wit recowery mode to write back ?
Stop worrying about what can go wrong, and get excited about what can go right.
PRESS THANKS IF YOU LIKE MY POST AND IT HELPED YOU
Yes i already tried recover mode and this not work.
Any suggestion?
Any suggestion?
Contact alientech and let them solve the problem.
I already asked they said go to mercedes dealer ... great support
i done that car with cmd,work via obd
You have cmd slave or master ?
Cmd is better then this shit kess ?
Try to write directly to the bench, without calculating the checksum.
Ecu tuning, DPF, EGR, LAMBDA, ADBLUE and DTC, Remove
@tonih
Not possible on the bench, no tool can do it via bootmode.
Do you have a schematic for pinout ?
Yes, :
Pin1 and Pin19 +12volt
Pin 2 Ground
Pin 41 Can H
Pin 54 Can L
where you found that informations?
