On label there is only written 2mm Cutter HSS.
Made in Germany.
I can buy these for you and send you.
I just cut one VA2 blade with this cutter,it did the job perfectly.
yes please post a picture of it.. thanks!
I was looking at these
But sent a email off to kkkcut to see what they come back with first..
Made in Germany.
what machine you using to cut?
How much are they i would need them shipped to AU
I am using Silca Club - very old machine,but reliable.
Get me prices on them to please.
Guys,our member "Fallen" will get measurements of the cutter he uses on his A9.
Then we compare it with this cutter.
I tell you,nothing can compare with this one.In terms of cutting strong keys.
OK,your cutter against mine measurements.
Shaft Length - Your 40.9mm x Mine 30mm
Cantilever Length - Your 14mm x Mine 10mm
Cutter Length - Your 6mm x Mine 4mm
Shaft Diameter - Your 6mm x Mine 6mm
I think this can fit A9 Machines perfectly.
Photos of the cutter will be uploaded tonight.
Fallen (30th April, 2015)
The cutting length is important.
The A9 uses the length of the blade to cut flat keys with.
The machine positions the cutter at 3mm up from the end so it's in the middle of the blade.
That's why all the A9 cutters have a longer cutting blade.
Shame as the cutters your talking about sounded good.
I was wrong cutter length is 5mm.You could take fewer pieces and try them out.
Here is one picture,compared with standard ORION cutter.
Also many members asked.
On the cutter it says:
2,C - Ultra
52/14 CC1*
Fallen (1st May, 2015)
Who ever has one of these what software version do you have??
version 11.2. i speak with support they told me new updates after 1mnd.
somebody can look on machine this configuration how much must be XY i reseted mines and now machine stopped cut.
