immo is in 27c512 mate.first write swap file start car swich off in 30sec.write ori and as you due remove box.
good afternoon all m8's today happen't somethink very crazy...i have one ecu from citroen xanthia with number's:
IAW 8P13.inside has one mcu motorola HCP11A1 and one 27C512.the immo is on the mcu ok?i clean with immo tool and with immo decoging 3.2....when i go to the car i remove the immo box near the key....open the switch on but the light from immo FLASHED..i disconnect the plug from ecu and open the switch but same again the immo light....any one guy know hot to make immo off on this f@@@ng car?????
i post and my ori dump's
regard's and thank'sAttachment 260349Attachment 260350Attachment 260351Attachment 260352Attachment 260353
antwnhszr (20th May, 2014)
You do one of the methods not both...
In Decoder select "MAGNETI MARELLI IAW 8P.XX SWAP EPROM - Totale/Parziale"
You do not need the dump from Your 27C512. Just follow these instructions:
1) Click on save
2) Unzip the saved file
3) Program a new blank EPROM 27C512 with this file
4) Replace the ORIGINAL 27C512 with the above.
5) Turn the ignition ON for 30 seconds (do not start the car)
6) Turn off the ignition and replace the 27C512 with the ORIGINAL 27C512
7) Remove the immo box for Total immo off.
8) Start the car
Try and post result please.
B.R.
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
antwnhszr (20th May, 2014), Caarlosalfredo (14th September, 2017)
thank you gyu's for your opinion's but o make this opoeration 3 time's.the immo box is that near the key?or exist on another location?
regard's
hi
you must read the mcu motorola HCP11A1 and for make the clear or off , all bytes in FF
fab
the imoo decoding 3.2 make that.all line's is FF expect the last line . i try and like this. but nothing chainge.
regard's
try thsi dumps
Immo box is located on the steering column and it is a plastic black box.
Do not forget to look for an original file for Your EEPROM as the one You posted is probably damaged... and no matter what You do You will have problems with it...
The second option by the MCU is also correct but most of the time the clone programmers do not do that good of a job reading and writing the Motorola MCUs and people get confused with the results. If You have original Motorola Programmer then You can try.
B.R.
the problem solved....the immo box is behind of the glove.....the operation has as:i put the clock file on the 27c512 , open the switch for 3 minute's,close the switch , remove the yelow plug from immo box ,and cut 2 pins from ecu:10and 15 ... and i put on the ecu the original 27c512..... the car start ....
thank you all guy's for your time.
Does the battery terminal need to be removed when replacing the chip?
Be sure to cut off 10 and 15 pins?
