Post nrs of dash, someone Will give you new dump, put this in your dash and make proxy allignment.
Wbr Adam.
hello friends, I have a problem with a dashboard magnerti marelli from an iveco daily 2006 without tacograf. In dasboard, have a memory 95040. This is arrived at 999999km, and then it stopped with many _ _ _ _ _ _ _ _ _ in the display. I put the km 0 with nyo and all is ok in the display, but the miles, not increase. Always 0, partial and total.
Can anyone help me solve this, I do not know how to do.
Attached are the file ori and mod in the 95040
Thanks in advance
Wbr Adam.
Hi friend, thanks for your reply. But i don't have nrs of dash because it is mounted on the daily and now the owner is using it to work. You can post all the dump you have for this dashboard, so I can write when read the code?
And other question: how i can do the proxy allignment? I can with multiecuscan and elm327?
Thanks in advance friend.
eiemax (26th May, 2014)
Friend, you can post the dump that you have for this dashboard?
hi,
try this(5 files)
Download ivecoMM2007.rar from Sendspace.com - send big files the easy way
hi
try and erase km in ecu !
if it works cursor speed? diagnostics would help a lot here
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
yes, cursor speed work ok
is possible to reset the km in the BCM?
Change KM in BCM - over 999999km does not count.
Iveco only.
