Results 1 to 3 of 3
    Default EDC15 RENAULT F9Q
    Hello! someone can delete a dtc of a renault megane 1.9dti. its in limp mode. and the code fault is P1020
    Renault Megane 1.9dti F9Q744 2001 year
    Attachment 261522
    Thankss
    There are no solution?
    Apr 2012
    wolomin poland
    this dtc is informing you about problem with fuel pressure you cant just erase it form ecu. propably your pressure regulator in fuel pump is dead. you need to diagnose its more carefully and fix the problem. this is only one solution
  4. The Following User Says Thank You to lonczyn For This Useful Post:
    ollync (24th July, 2019)
