Results 1 to 11 of 11
Thread: the end is near
    Default the end is near
    Now we have all heard the news, can the skybox team update or make new boxes to counter the newvchanges currently taking place?
    Apr 2014
    No they wont be able to. New encrypted channels, the end is here I'm afraid.
    So our skyboxes will be no good in three months time I imagine
    Is this encryption nagravasion 4?
    joe516's Avatar
    Mar 2008
    manchester
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
    ar5ena1
    Guest
    From what I can tell, SD channels will be unaffected. HD channels will go however. I presume FTA HD channels will be fine....
    Apr 2014
    Just all payed HD channels will be gone in a few months time. As long as we still get to keep SD its still better than S*y sub. Maybe we will move back to cable again?
    May 2012
    West Mids
    I think most boxes will be at an end unless some brainiacs can come up with a fix to sort it otherwise once the HD channels have gone i dont think the sd ones will be safe. i feel sorry for ppl how have paid year long subs and boxes for stupid ?100s i came across this post on another website lets hope its to be . untill all the channels have gone i think it will be tsmedia for me after it all .
    in a way i think it wont take long to find a bypass . if im mistaken but how would sly add new software to the old hd boxes and get it to stay if you think about it if its been put there then theres a way it can be altered, any ways heres a post i found
    "The new pairing is based on the hardware pairing chip, that is already broken as we all seen on the past 18 months hardware pairing emulation for Conax was released, as well as other systems. There is few studies also published about this hack. The same chip and code is doing this hardware pairing you are talking about as well as the Conax or other CAS.
    I was also told that a new box is coming (not linux) from the usual people at the origin of the working "3 months cards" such as K3, Knot2.x, Millenium, Abracadabra, Omnia, Opos, that is emulating all the hardware pairing for the various CAS... all this based on a hacked ST chipset.
    So the hardware pairing is broken, it now seems to fall on the hands of the old good "3 months pirate card" german mafia suppliers, but it would probably soon go to Linux boxes as piracy of pirate products is the usual way... (due to very bad quality and full of bugs software, easy to extract / hack, for sure more easily than the original product from CAS)".
  9. The Following User Says Thank You to venza1 For This Useful Post:
    utdman (30th May, 2014)
  10. #9
    Jan 2013
    would this also affect cable boxes has well. might make a jump across . I presume its more or less same to set up
  11. #10
    joe516's Avatar
    Mar 2008
    manchester
    Quote Originally Posted by valhalla1 View Post
    no m8 cable r ok
  12. #11
    Yes they are fine. However, there is no way of knowing how long for as they could follow same route as $ky. Although it's likely to be lot longer than $ky I'd say.
