take es and all table be off
mate p0601 is your only foult code you have?if yes maybe not ecu fail but the plastic barrel round the key?did the car make check when swich on?
Hello.
I have only one fault code P0601.
Car is after crash mileage correction and I don't know is that my fault or maybe it was before.
Car starts fine and works OK.
Of course I don't need to remove all DTC table because I have only P0601.
I don't know the procedure how is faster to remove one DTC or all the table.
Work is a primitive way to spend Your free time.
F.Kiepski.
here mod file.
Best regards.
thats the reasoi ask mate.in punto-fiorino this is commonproblem.the solusion is plastic barrel with key ring.the other way is babos file.good luck.
fiorino and punto with p0601 have two reaction.1st car dont make check when swich on and dont start.2nt everything works fine as yours. in the first is ecu fail.2nt is the ring where you insert the key.this is what it happent in my case.first i change ecu cause i never test dtc remove and the other the barrel ring.
post results
GARAGE0864
With Babos file I have DTC U0426 and car starts only once.
WIth Slave file car starts but I have P0087, P0645, U1706, P0110.
F.Kiepski.
I have tested solution for dtc in this ecu. PM me
meteor80 (30th May, 2014)
Hmm.
It says that checksum is calculated.
F.Kiepski.
