Results 1 to 3 of 3
Thread: edc15c2 renault
    Apr 2012
    minsk
    Default edc15c2 renault
    Hello... i was egr off by switch in renault espace edc15c2
    72725 8bit change from 001 to 000..... egr close.... renault can clip display 0%..... but engine very bad work and after some minuts - stop.... max rpm - 1450.... i also remap this file for more power, but without egr switch - engine work good...... in other car(renault espace edc15c2 ) - work good by this method......
    how i can close egr, exampe: with unplugging sensor by delete DTC..... or close map EGR????? help please
    Jun 2013
    EU
    EGR off by switch need the electrovalve to be disconnected, otherwise stays fully open without the ECU noticing it, and engine stall.
  3. The Following User Says Thank You to morgano For This Useful Post:
    Romaus (8th June, 2014)
    Apr 2012
    minsk
    Ok, i was disconnect and car good work... Big thanks
    Отправлено из моего iPhone используя Tapatalk
