Results 1 to 14 of 14
    happy_highlander's Avatar
    Aug 2010
    Default H_H UK and Euro E2 Sat and Cable combo list
    Have a try of these if you have a combo linux box
    I have used my normal E2 uk and 4 sat euro but added cable to the list with some new favorites that are a bit of hybrid set with channels from both sat and cable in the same favorite. Obvious example is the hybrid movies favorite which has all the sd movies from sat with the hd from cable.
    Euro Sats are 13, 19.2, 23.5 and 28.2 you may need to ftp the cable.xml into your box seperately as dbe doesn't always send it. If you need to know where to put it check the settings in dbe for where your satellite.xml gets sent
    Latest Lists are at the end of the thread or just press Here to jump straight to them.
  2. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    mrmack25 (12th September, 2015), WOODWARD395 (6th July, 2014)
  3. #2
    Aug 2010
    New Lists Correct to 28-06-14
    Not many tp changes but I think all the UK Sat $HD are now removed
  4. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    ndiqbal (19th July, 2014), WOODWARD395 (6th July, 2014)
  5. #3
    Aug 2010
    New Lists correctto 10-08-14
    E2 UK Sat & Cable Picons to match
    http://www.mediafire.com/download/y9...n_10-08-14.rar
  6. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    jenseneverest (25th August, 2014), WOODWARD395 (21st September, 2014)
  7. #4
    Aug 2010
    New Lists correct to 20-09-14
    UK Picon pack sat_and_cable_picon_20-09-14.rar
  8. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    skybot1 (27th September, 2014), WOODWARD395 (21st September, 2014)
  9. #5
    Newbie WonkoTheSane's Avatar
    Feb 2013
    Sounds like these files are what I am looking for. Is there a Bouquet file that covers Astra 28 and 19 and Hotbird 13?
    Being a little fresh to the Satellite game do I need a combination file for all three satellites or three separate files, one for each satellite?
    I have 3 LNB's into one cable so not a fantastically complex setup..
    Wonko.
  10. #6
    digicon's Avatar
    Happy H's channel list will work absolutely fine on your setup although it does include 23.5? east this is very easy to remove via either the bouquet edit feature on the receiver via the remote control or load the list into dreambox edit and remove them that way
  11. The Following 2 Users Say Thank You to digicon For This Useful Post:
    happy_highlander (26th October, 2014), WonkoTheSane (26th October, 2014)
  12. #7
    Aug 2010
    Quote Originally Posted by WonkoTheSane View Post
    Wonko.
    This one is better for you. http://www.digital-kaos.co.uk/forums....php?p=2383820 you will still need to remove 23.5 but it doesn't have cable on it. These are due an update within the next week or so keep an eye out for fresh lists
  13. The Following User Says Thank You to happy_highlander For This Useful Post:
  14. #8
    Feb 2013
    Thanks both. Have just fitted a 2.5 HDD to the DM7020HD (yes, that's possible! ) and will be plugging in over the next week so will check them out and try to load and see where I get to..
    Wonko
  15. #9
    Aug 2010
    New Lists Correct to 01-11-14
    UK Picons E2_UK_Sat_&_Cable_picon_01-11-14.rar
  16. #10
  17. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    dr0g0 (30th December, 2014), mickm1 (22nd December, 2014)
  18. #11
  19. The Following 3 Users Say Thank You to happy_highlander For This Useful Post:
    digicon (2nd May, 2015), joe516 (2nd May, 2015), maca (2nd May, 2015)
  20. #12
  21. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    digicon (6th July, 2015), joe516 (5th July, 2015)
  22. #13
  23. The Following User Says Thank You to happy_highlander For This Useful Post:
    digicon (22nd August, 2015)
  24. #14
  25. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    digicon (31st August, 2015), P&D (10th January, 2016)
