Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Default Mini - EDC16C35 - ISN Mod
    Hello. I need help me.
    I Need adapt this ecu used in this cas3.
    In the cas I have the ISN, but in the ecu I don?t found the isn.
    Can I help me? Please.
    The ecu is EDC16C35 - 1.6
  2. The Following User Says Thank You to InfoPerformance For This Useful Post:
    minchion (29th October, 2017)
  3. #2
    rex89's Avatar
    Jul 2009
    Not Near Tricore MCU
    hi guy write this is only on eeprom of u cas , then make good sync with avdi or INPA and start engine then.
    let me know result
    pass in u pm already
    Imagination is more important than knowledge, because knowledge is limited ... while imagination creates the world.
  4. The Following User Says Thank You to rex89 For This Useful Post:
    InfoPerformance (10th June, 2014)
  5. #3
    Solved the problem.
    Can you mod the vin? I don?t mod the checksum for vin.
    Thanks. Regards.
  6. #4
    bearheroes's Avatar
    Dec 2011
    Your files.
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  7. #5
    Please, can you send me the pass?? Thanks.
  8. #6
    Jan 2010
    hello please help me for mod isn in cas 3
    ecu edc16c35
    thank you very much
  9. #7
    Jan 2010
    hi i found isn ecu c4 3f but i can't seem to put it in the case i must have a checksum error if someone could do it would be nice thanks
  10. #8
    doctore's Avatar
    Nov 2015
    Colorado Denver
    here you goo
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  11. The Following 2 Users Say Thank You to doctore For This Useful Post:
    romucifer (5th February, 2020), weld88 (4th February, 2020)
  12. #9
    Jan 2010
    Quote Originally Posted by doctore View Post
    here you goo
    hello thank you but no synchronization possible error handling cas of dde
  13. #10
    Jan 2010
    hello please new not work
  14. #11
    Jan 2010
    hello functional car but still not find a solution to buy a set cas3 dde same hw and sw and key believing that there was maybe a material problem I have to recover at the ktag eep and flash of the new dme and eep of the new cas3 by injecting them into my dde and my cas3 the vehicle synchronizes dde and cas3 and the car starts so I must have a software problem I would like to make my dde and my cas3 work again with my keys here is dump of my cas3 and flash and eep of new edc16c35 which could control and change the isn to be able to synchronize my cas3 with my dde to flash with the new dde thank you but i not eep cas3 corrupt
    isn dde 4b58
    isn cas3 993f
  15. #12
    Jan 2010
    for kiszka eep cas3 new work in new cas3 and cas3 ori
  16. The Following User Says Thank You to romucifer For This Useful Post:
    kiszka (9th February, 2020)
  17. #13
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by romucifer View Post
    thanks .......
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  18. The Following User Says Thank You to kiszka For This Useful Post:
    romucifer (9th February, 2020)
  19. #14
    Jan 2010
    hello these configuration that I can't synchronize
    cas3 + origin
    flash edc16c35 occassion meme hw et sw
    eep edc16c35 origin
    wine wmwmg31080tu46048
    manual gearbox
    starter ok key ok but no synchronization of case3 + the engine does not work
  20. #15
    bearheroes's Avatar
    Dec 2011
    write this file to cas and use istaP
  21. The Following User Says Thank You to bearheroes For This Useful Post:
    romucifer (10th February, 2020)
