bendy (8th April, 2021), mcskrillz32 (9th August, 2021), miha99 (19th July, 2023), pagadi5 (23rd January, 2018)
HELLO MATES..
I need some help.
I bought an emulator for BMW ews2, ews3
It uses a software called ews2 emulator.
I got it from my provider.
I tried to install it in windows 7 64 bit and windows XP professional spk3 with no luck.
But I get a message that says that I am missing a file EWS2emu.cab
I don't find it anywhere...can someone help me?
I attached the software I got from the vendor.
thanks in advance !!!
cheers mates.
My wife said that i have no hair, have big ears ..but a great smile.
open the archive
go into the folder EWS2emu
start EWS2emu.exe
for me it works without problems (Win XP SP3 and Win 7)
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
I tried on both, windows xp pro spk3, and windows 7 home spk 1 and no luck...dont know what am I doing wrong.....
yup...
thats exactly how it works....
for me too, not a problem.
The difference between men and boyz...Is the price of there Toyz.
LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
hello what is the error you get on your computer , most times your computer is missing a dill or ocx file or something like that .
cj
Some times when you try to execute the software ( EWS2emu.exe) it gives you a fail massage of file * MSSTDFMT.DLL* that needs to be on your pc.
below is the attached copy of the fix, it contains 2 files, the .bat file that does everything automatic....but only on windows xp...did not work on windows 7 64 bit for me.
I only tested it in windows Xp pro SPK3 and worked, at least it opens the software now.
Hope this help someone.
cheers.EWSAdded.rar
306 t16 (10th August, 2019), aussiediag (19th May, 2021), ettaoussi (23rd October, 2016), hilton in brazil (17th October, 2020), jaruntje (17th March, 2019), radoslawwiklik (26th March, 2015), wflseba (16th September, 2014)
I need some help mates...
Here is the situation.
I have a 1990 BMW E30.
We installed an 1999 M3 engine into the E30 above ( M3 engine S32 made for the USA Market).
The engine computer is a SIEMENS DME MS41.1 ( original from the M3 engine above ( fig1)
We are having troubles with the INMO, since we only swapped the engine, engine harness and ECU from the original M3 to the E30 chassis.
Therefore the car is immobilized due to lack of the EWS computer, ignition antenna and so on.
I got an EWS2 emulator from china.
I am using the software *ews2 emulator* from RobinDAB.
Laptop is a dell d630 running windows Xp pro SPK3.
The emulator instructions said that I need to use any kind of SERIAL to K line connector, such as D-CAN, STD:OBD, VCDS com version, VAGPROG, etc.etc.
I have a KWP 2000 serial to k line adapter, therefore I figured it can be used as well. FIG 2
Note that my interface is USB, NOT serial COM port?but FIG 3 shows it is a serial to K line interface as needed for the use of the EWS2 emulator software from RobinDAB...thererfore I assumed I was using the right K line adapter.
I tested my KWP 2000 into the car and see if communication was ok. Fig 4 shows that everything so far is working fine.
I installed all the wires just as the manual said, and jumper is installed on the emulator to do the programming.
But when I tried to read both SIEMENS ECU and EMULATOR, the message at the bottom of the display say: NO ECHO FROM KLINE..
FIG 5 shows the issue.
So, I am stuck...don't know if the KWP 2000 is not good to work on that software or if the china emulator2 is bad....
I tried on other BMW with EWs and same results..
Any ideas how to solve my problem are very welcome...
way you not make immo off on the ECU?
dont know how to do it...I read that you need to desolder an eeprom out of the board, but I dont know which one....the photo shows the internals of the DME.
then read the eprom, and re-write the info with a bin file.
It would be great If I could find guide somewhere on how to do it...
I have expirience in electronics, and also I am an automotive technician, plus I repair a lot of other electronic automotive devices and diagnostics equipment, therefore I think with a little push on the right direction I will manage to do it.
thanks for the help mate...
looking for EWSAdded.rar it will not let me download it. tells me I am not logged in so when I log in again the login page just keeps reappearing
it keeps telling i have no permision to download the added files. first file i can download.
Is anybody have to work this in windows 10 64bit?
help. I have this problem too, and i dont know how to decide this problem
