Results 1 to 5 of 5
    autodigitec's Avatar
    Aug 2011
    PT
    Default Clio 4 9S12XHY256 Software (Files needed)
    Hello everyone, I'm writing a small software purely for learning purposes to handle Clio 4 odometer in 9S12XHY256 mcus.
    I currently think I have 2 working algorithms, but the dumps are very different from each other.
    What I'm asking from you is, to post your clio 4 dashboard dumps and how many kms it has.
    Or if you know an algo and want to submit, it would also be great
    In the end I'll post the software here on digital-kaos.
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by autodigitec View Post
    Are you writing software for 1000's versions? Every dump is different so what you are doing is impossible unless you know how it works.
    Aug 2011
    PT
    Quote Originally Posted by drpeter View Post
    So you havent seen dumps from 2 different cars with the same format?
    Moderator
    PremierD's Avatar
    Jun 2009
    No mate .. Its a dflash ...Virtual eep so it can be anywhere and repeated hundreds of times .. and mirrored .. so good luck
    PS the algo is easy .. and so is the crc..
    Aug 2011
    PT
    Quote Originally Posted by PremierD View Post
    So technically, if algo is the same and only offsets change, it's still possible to make a calculator with the need of asking what is the current mileage of the dash.
    I really wish people would share me some dumps so I wouldnt make silly questions
    Is it possible to display mileage on dash connected on bench? Or needs can emulator?
