Results 1 to 15 of 28
Thread: Smart 1000
    Nov 2013
    Default Smart 1000
    Hello everyone, I am seeking your help in relation to a 2007 Smart 1000:
    I made the change in the Km in DASH and BSI, reassembled everything and the car has the following problems:
    The dash lights remain lit on without key inserted
    The machine does not start
    the display panel is dead
    In diagnosis: communication problem can
    Does anyone have any idea?
    Thanks in advance
    dashradio's Avatar
    Inafield
    Why did you start a new topic when you already have the same topic running ?
    http://www.digital-kaos.co.uk/forums...1000-a-424083/
    Jun 2009
    porto portugal
    car need to work without dash, try check BSI, check solder points if you take mcu off
    regards
    not not
    this car not start without dash fitted
    dashs is part can gateway
    regards
    Jan 2011
    Post dumps DASH and BSI
    Nov 2013
    Quote Originally Posted by dashradio View Post
    Oppsss...
    Nov 2013
    I saw your previous time ...
    Nov 2013
    Solder point ok, read and write ok, mileage and vin ok... :-(
    Nov 2013
    Quote Originally Posted by Gizbern View Post
    I try post dumps , thanks...
    Nov 2013
    Here is the dump of the dash, in fact, something was missing ...
    I have corrected, can someone check ..?
    davecooper47's Avatar
    Dec 2010
    Dash would not stop the car from starting. Where is the dump from BSI?
    Jan 2011
    I tested, Dump is not ok, Car not started
  13. #13
    Nov 2013
    The readings in kilometers was correct, but lacked the Vin in two other areas ...
  14. #14
    Nov 2013
    This is the original file. Can anyone help me fix this?
  15. #15
    Hello, your file check
