Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Oct 2011
    thanks pic18f2550
    could you possibly send me the dump of the flash 29c512, in case the immo off does not work, then I can try today both if I can, because of time difference, all the best
  2. #17
    Oct 2011
    I tried the immo off file and the immo light doesent come on at all which I think is correct, it use to flash 3 times and go out, the engine cranks but no spark, also another thing I cant connect with mvp or avdi via obd to ecu, any ideas where I can look, I think I need to do the flash chip next then out of ideas , anymore advice appreciated
  3. #18
    Nov 2013
    Alg?ria
    Quote Originally Posted by raptureready View Post
    plase wait me for the flash 29c512 what I expect adapter to read it
    for no spark, if can you check the "Engine speed sensor / Camshaft position sensor / it's wires if good and no cut" ?
    can you scan and give us the "fault code" ?
  4. The Following User Says Thank You to PIC18F2550 For This Useful Post:
    raptureready (20th June, 2014)
  5. #19
    Nov 2013
    Alg?ria
    here is the file eeprom at29c512 AT29C512 OK.rar good luck
  6. The Following User Says Thank You to PIC18F2550 For This Useful Post:
    raptureready (22nd June, 2014)
  7. #20
    Earth
    Hello rapture did you start the Hyundai atos, I have the same ecu, no 95040! could you please tell me how did you start?
  8. #21
    Oct 2011
    never got it started, customer took ecu back to scap yard, I think he got another ecu with a working key, never heard again , sorry
  9. The Following User Says Thank You to raptureready For This Useful Post:
    XJTAG (2nd April, 2018)
  10. #22
    Sep 2021
    there is a firmware
    Hyundai Athos 1.0
    there is no eprom
