Page 1 of 82 1234561151 ... LastLast
Results 1 to 15 of 1226
    Default Passat 95320 Comfort Module B6 B7 CC 3C PIN and CS Topic
    Please post in this topic your file from CCM and someone or i give CS and PIN. It is annoying that everyone create new topic.
  2. The Following 6 Users Say Thank You to autofan1965 For This Useful Post:
    f21 (5th February, 2021), Faraday (28th January, 2015), karter1 (1st November, 2019), obdsystems (12th August, 2015), u.s (15th June, 2014)
  3. #2
    Default B6
    could you calc CS and Pin out of this dump?
    thnx in advance
    comfort95320.rar
  4. The Following 7 Users Say Thank You to cammy25 For This Useful Post:
    Cromwe11 (9th May, 2018), f21 (5th February, 2021), Papiti56 (30th November, 2015), sasa5 (10th January, 2016), silo1992 (22nd November, 2019)
  5. #3
    vlado kljucar's Avatar
    Sep 2013
    Montenegro
    Login: 22773
    VIN: WVWZZZ3CZ7P003912
  6. The Following User Says Thank You to vlado kljucar For This Useful Post:
    seal777 (1st March, 2020)
  7. #4
    thnx ,but that can be done with AVDI. I really need CS for adaption.
  8. #5
    gwee's Avatar
    Dec 2012
    unknown
    CS : D2 9C D6 57 A5 39 AC
  9. The Following 11 Users Say Thank You to gwee For This Useful Post:
    Bishop c4 (14th September, 2014), cammy25 (26th July, 2014), cjawahir (26th July, 2014), easternghost (9th October, 2014), Fallen (26th July, 2014), gepakg (26th July, 2014), keysph (26th July, 2014), pezao (9th October, 2014), PremierD (26th July, 2014), triak88 (15th September, 2014), vlado kljucar (26th July, 2014)
  10. #6
    I can only confirm that is correct
  11. The Following 2 Users Say Thank You to autofan1965 For This Useful Post:
    cammy25 (26th July, 2014), gwee (26th July, 2014)
  12. #7
    Szczecin;Poland
    I need pin and CS
    No army may enter that land
    That is protected by polish hand
    Unless you are 40 to 1
    Your force will soon be undone
  13. The Following User Says Thank You to bugajewski_pl For This Useful Post:
    digikeys (13th February, 2024)
  14. #8
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    PIN: 15114
    Component Security Bytes: 2B A4 EF B0 57 49 DF
  15. The Following 3 Users Say Thank You to simaservis1108 For This Useful Post:
    Bishop c4 (14th September, 2014), bugajewski_pl (13th September, 2014), Faraday (13th October, 2014)
  16. #9
    cjawahir's Avatar
    T&T
    Quote Originally Posted by bugajewski_pl View Post
    I need pin and CS
    pin --15114
    cs---2B A4 EF B0 57 49 DF
    CJ
  17. The Following 2 Users Say Thank You to cjawahir For This Useful Post:
  18. #10
    Szczecin;Poland
    thanks guys, pin and CS are correct.
  19. #11
    Hello I need please PIN/VIN /CS from this passat confort module.
    PASSAT 2007
    3C0959433
    SW 0434 HW 038
    HELLA W42 21/03/05 P004-1226
    5DK 009 064-00
    EEPROM 95320
    I have error 0003 control module defective, It can be solved with Odis by flashing, but I want to have all data beforemake something wrong. Car now is crancking with all keys, but sometimes gets error and dont cranck.
    Thanks beforehand
  20. The Following User Says Thank You to GolfmkI For This Useful Post:
    Elektrik001 (19th September, 2019)
  21. #12
    Moderator
    PremierD's Avatar
    Jun 2009
    VIN: WVWZZZ3CZ6E024119
    PIN: 43938
    Component Security Bytes: 84 C9 8A 35 09 93 14
    There you go mate ....
  22. The Following User Says Thank You to PremierD For This Useful Post:
    GolfmkI (9th October, 2014)
  23. #13
    Quote Originally Posted by GolfmkI View Post
    PASSAT 2007
    3C0959433
    SW 0434 HW 038
    5DK 009 064-00
    EEPROM 95320
    Thanks beforehand
    You can change just eeprom content between units.
  24. The Following User Says Thank You to autofan1965 For This Useful Post:
    GolfmkI (10th October, 2014)
  25. #14
    Thanks PremierD!!!
    It is working perfect!!!
    Autofan1965 I prefer the Odis procedure, I have just done.
    Flash was about 6 minutes, and this way you dont need any donor unit, you simply repair original.
    Car is working perfect now!!
    Odis could repair lot of units that have tipycal error 00003 defective and so on..
    Its a bit risky sometimes, but when you use it theres not so many other choices.
  26. The Following 2 Users Say Thank You to GolfmkI For This Useful Post:
    Elektrik001 (19th September, 2019), HeXeN (11th April, 2015)
  27. #15
    Jun 2011
    Passat CS + PIN.rar
    hi got another that I can not read the pin yet, can anyone help with CS and PIN
    thanks zip
  28. The Following User Says Thank You to zippy82 For This Useful Post:
    willyboy28 (15th April, 2018)
