Page 43 of 82 FirstFirst ... 33383940414243444546474853 ... LastLast
Results 631 to 645 of 1226
  1. #631
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by pritorgas View Post
    need pin to match replacement key with full vcds, vehicle is passat 3C 2006 with smart key
    you need not only pin,you need and coponent security.
    for add new key you need preapay key to dump and after add key used vcds
  2. The Following User Says Thank You to rola1971 For This Useful Post:
    pritorgas (5th August, 2018)
  3. #632
    Member trivilin8's Avatar
    Mexico
    Like they say, as far as I concern vcds can't make it to even key matching, if it is 4th generation you might taking pin and cs from CCM as they say, either from hardware with a programmer or with avdi, vvdi or even fvdi, if it is 5th generation you can't do anithing with vcds I've been there, unless ross-tech already update software
    Sent from my BLA-A09 using Tapatalk
  4. The Following User Says Thank You to trivilin8 For This Useful Post:
  5. #633
    Aug 2018
    Quote Originally Posted by rola1971 View Post
    this passat b6 3C 2006(.5) 2.0t has immo3. ross-tech wiki has procedure to match additional keys with one orig key in hand, using vcds but requires pin login to get into adaption. any advice how to get the pin without pulling the ccm?
  6. #634
    M3L3R's Avatar
    Mar 2014
    Kolobrzeg
    You can get pin from engine ecu.
  7. #635
    rola1971's Avatar
    Jun 2014
    Dublin
    it is immo4 in you car
    you need pin and cs
    if you dont have tools dont play locksmith
  8. The Following 2 Users Say Thank You to rola1971 For This Useful Post:
    Gavra (5th August, 2018), pritorgas (6th August, 2018)
  9. #636
    Apr 2017
    With good tools you can do it from OBD or just clone chip and match remote with OBD
    Good luck
    Verzonden vanaf mijn iPhone met Tapatalk
  10. #637
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by mustafabahar View Post
    Good luck
    it is id46 keyless key no posibility clone
  11. #638
    Aug 2018
    you need pin and cs
    thanx, I stand corrected
    Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
    Component: IMMO 041 0364
    Revision: 00041000 Serial number: VWZCZ000000000
    (from vcds) is apparently immo4
    can you point me to the procedure to
    1) get the comfort module out of a Passat 2006 3C (I understand it is behind the glove box)
    2) advice on reading the eeprom (I understand I need a common eeprom programmer, but is in-circuit with test clip possible, or does the eeprom need to be de-soldered out ?!)
    I aim to get the eeprom dump to upload here in order to get Pin and CS, VCDS offers procedure to match key with one orig key on hand
    http://wiki.ross-tech.com/wiki/index...g#Key_Matching
    I have received snippets of replies above, some conflicting but unfortn not directly actionable
    I am in a bind, dealership is cost prohibitive, locksmith service even worse price gouging. I got IT background, handy with a solder iron, just not having the car experience.
    Actionable advice is much appreciated
  12. #639
    Mexico
    Dude! This is the eprom you need to read, CCM is under right A pillar, you have to slice a lock to remove plug, unclip CCM's cap and fold four clips that holds front plastic cap.
    Good luck
  13. The Following User Says Thank You to trivilin8 For This Useful Post:
    pritorgas (7th August, 2018)
  14. #640
    super jumbe's Avatar
    Livingstone
    Hello
    Can anyone help with full pin, sc, mac from this file!
    Thanks in advance
  15. #641
    avital's Avatar
    Your data :
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
  16. The Following User Says Thank You to avital For This Useful Post:
    super jumbe (7th August, 2018)
  17. #642
    publiperro's Avatar
    Apr 2016
    España
    PIN 09782
    CS 98 F3 1D 9F 31 E6 3B
  18. #643
    publiperro's Avatar
    Apr 2016
    España
    [QUOTE = super jumbe; 3342827] Hola,
    ¿alguien puede ayudar con pin completo, sc, mac desde este archivo!
    Gracias de antemano [/ QUOTE]
    PIN 09782
  19. #644
    Top Poster Evaldazj's Avatar
    Could anyone CS? Thank you
    If post helped, allways hit thank's
  20. #645
    autochei's Avatar
    Mar 2013
    romania
    Dump recognized: OK
    Programmed keys: 2
    PIN: 37508
    CS: 3AA5994E754B32
    VIN: WVWZZZ3CZ6E192178
    VAG#: 3C0959433K S0455/H038
    Part#: HLO W42 08.02.06 P003 1431
    IMMO: VWZCZ000000000
  21. The Following User Says Thank You to autochei For This Useful Post:
    Evaldazj (14th August, 2018)
