Page 4 of 80 FirstFirst 1234567891454 ... LastLast
Results 46 to 60 of 1199
  1. #46
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    PIN: 52447
    Component Security Bytes: 23 5E 05 4D 3A D1 9C
  2. The Following User Says Thank You to simaservis1108 For This Useful Post:
    ninja123 (17th April, 2015)
  3. #47
    szuwarik's Avatar
    Jan 2011
    Hi need pin & cs from comfort dump please
  4. #48
    Moderator
    PremierD's Avatar
    Jun 2009
    VIN: WVWZZZ3CZ8E068978
    PIN: 00493
    Component Security Bytes: 80 0A 54 EF 00 14 A9
  5. The Following User Says Thank You to PremierD For This Useful Post:
    szuwarik (23rd April, 2015)
  6. #49
    Top Poster bachlar's Avatar
    hi, need pin and cs comfort dump please.
    Thanks for your help.
  7. #50
    Jun 2013
    I get unknown version. Can you read it as ST_M95320 . And new dump. Maybe it will work better.
  8. The Following User Says Thank You to Weasel3 For This Useful Post:
    vorovei constantin (23rd May, 2015)
  9. #51
    VIN: WVWZZZ3CZ7P027685
    PIN: 11116
  10. The Following User Says Thank You to Evimix For This Useful Post:
    bachlar (25th May, 2015)
  11. #52
    Oct 2010
    Dublin
    Hi ca i get CS from body module.
  12. #53
    Login: 48781
    VIN: WVWZZZ3CZBP314XXX
    Comp.: E1 1D 4C 3B 39 EC B9
    MAC: 9B 76 8D 58
    Your help rate to question rate is very bad.
  13. The Following User Says Thank You to autofan1965 For This Useful Post:
    snake80 (17th June, 2015)
  14. #54
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Hello, need pin code for passat b6 2006 year. All ways I'm using TM100 to calculate this, but this time it not working for me, why don't know, after load file, tm100 say me use hitag to make key and do not calculating cs and pin... So please help, it very urgent. Thank you.
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  15. #55
    Aug 2013
    Serbia,Belgrade
    Your Passat is Keyless-GO.
    This is not ID48.
    PIN: 06846
    Component Security Bytes: 3A B8 46 0A 75 70 8C
  16. The Following User Says Thank You to simaservis1108 For This Useful Post:
    Saulius Saulius (18th June, 2015)
  17. #56
    topclef's Avatar
    yes, this Passat using keys ID46 , not Megamos 48
    anyway Pin Code : 06846
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  18. The Following User Says Thank You to topclef For This Useful Post:
  19. #57
    Aug 2010
    Herts, UK
    ~~~~... something wrong... Car do not accepting this code...
  20. #58
    Aug 2010
    Herts, UK
    after few attempts to put this code, now saying it a security time...
  21. #59
    Moderator
    PremierD's Avatar
    Jun 2009
    VIN: WVWZZZ3CZ6E069108
    PIN: 06846
    I get the same mate .. change the vehicle .. it may work
  22. The Following User Says Thank You to PremierD For This Useful Post:
  23. #60
    Aug 2010
    Herts, UK
    yea, got it from 6 different places, code same, but car do not accepting, always refuse....
