need pin from comfort 95320
anf_andrei (20th April, 2019)
i change with new escl and all works perfect! thanks for help!
Hello there,
I need the pin and CS from 2016 Passat CC, 95320 attached. Thank you!!
Hi. Please read login and cs from dump passat b6 95320 from komfort modul. Thanks
Hello
I need pin code for passat B6 2006 2.0 TDI
I read Comfort module 95320
I need to adapt second key
""Just press THANKS when you think it is useful""
ubistvo (15th May, 2019)
u need pin cod and cs to precode transponder
Dump recognized: OK
Programmed keys: 2
PIN: 57835
CS: 97061C2F2E0C38
VIN: WVWZZZ3CZ7E012740
VAG#: 3C0959433R S0472/H042
Part#: HLO W42 23.05.06 P004 0330
IMMO: VWZCZ000000000
I will test and report
I need litlle help
How to precode with zed bull??
I never do that and only have 1 transponder
zedbul don t have thys option u need fvdi2
S O L V E D
The key is programed and all work OK
Prepare with CarProg coded with VCDS
Thanks to all
if I solder the 95320 from one comfort module to another the keys will work?
Steve
