Hello.
I need PIN, VIN and CS from this Comfort module.
Hello.
Work is a primitive way to spend Your free time.
F.Kiepski.
VIN: WVWZZZ3CZ6E117695
PIN: 54597
Component Security Bytes: 29 B2 65 1E 53 64 CA
That do mate??![]()
Maybe you can also give me MAC?
F.Kiepski.
Now only lack decobrir how to find CS.
PASSAT 2009 DUMP.rar![]()
Hi.
This is a file structure comfort. How to calculate the Green Zone?
Black zone calculate xor 8F19.
CS please.
VIN: WVWZZZ3CZ7E018712
PIN: 52276
Component Security Bytes: F3 28 13 5D E6 50 26
.. As requested ........![]()
Thanks Premier vin,pin,cs ok ... I counted MAC: DA31108D Forth from GREEN ZONE is calculated xor B549 in the attached post earlier.Where this xor?...hmm
Knowing the pin,cs from comfort can calculate the MAC and manually add to the ECU PPD1.x immo..works good![]()
The structure of the green zone: assume that xor 11 00 , this: pin 11 11 , MAC 11 00 11 00, CS 11 11 11 00 00 00 11. CS position sequence:
4AE-1
4A8-2
4AC-3
4AD-4
4B1-5
4A9-6
4B0-7
All repeated three times.
Thank you i get it but how you get the xor value ?
when i try with known dumps cant seen to find the xor value .... sorry or it seems incorect
Work in progress.........
