Page 74 of 82 FirstFirst ... 24646970717273747576777879 ... LastLast
Results 1,096 to 1,110 of 1226
  1. #1096
    rafal's Avatar
    UK - PL
    VIN: WVWZZZ3CZ8E148489
    Immo ID: VWZCZ000000000
    CS: FAC370F5F586E1
    MAC: B22CE4C3
    PIN: 62976
    Power Class: FE
    ELV: 49AC
    CCM Status: 6
    Key Count: 2
    Key1: 074A7716
    Key2: C50AAF18
  2. The Following User Says Thank You to rafal For This Useful Post:
    svrecar (10th December, 2021)
  3. #1097
    rafal's Avatar
    UK - PL
    Make sure a battery charger is connected so the voltage is maintained.
    [25-Immobilizer]
    [Adaption - 10]
    Leave channel at "00"
    [Read]
    [Save]
    [Done, Go Back]
    [Security Access-16]
    Enter the vehicle PIN in a 5 digit format.
    [Do it!]
    [Adaption - 10]
    Read Channel 051.
    The Stored Value will be 32000. Enter the PIN in the New Value box.
    [Test]
    Wait | N/A | N/A | N/A Will be displayed. Wait until the ID numbers are transferred into the first 2 boxes. If you aren't sure, be patient and wait at least 30 seconds!
    [Save] (Note: if Save is not available and the data in the last step has transferred continue by exiting)
    [Done, Go Back]
  4. #1098
    svrecar's Avatar
    this is exactly what i am trying to do.. no luck.
    cant find anything wrong ...
    edit:
    i just tried to use this login on ecu...and it works.
    on ecu works on immo does not .
    ffs...
  5. #1099
    Sep 2016
    Hello everyone,
    Can someone help me to decode the Pin code from this eeprom file?
    ECU Bosch EDC17CP14
    VW Passat B6 2.0 140
    Thank you
  6. #1100
    Sep 2016
    I just read the file from confort module.
    I need the Pin and CS number.
  7. #1101
    Quote Originally Posted by JBRACING View Post
    Your request!
  8. The Following User Says Thank You to cristo_844 For This Useful Post:
    JBRACING (27th December, 2021)
  9. #1102
    Please decode with power class.
  10. #1103
    Dec 2020
    Quote Originally Posted by Diablotic View Post
    Here:
    PIN: 47383
    POWERCLASS: FE
    CS: 9F 96 F6 07 0E 4D A2
    CCM: 758A
    ECU: B35B
    ELV: 4D8B
    IMMO: VWZCZ000000000
    VIN: WVWZZZ3CZCE155098
    SW: 0341
    HW: 083
    Immostatus: normal
  11. The Following User Says Thank You to Antonio266 For This Useful Post:
    Diablotic (22nd February, 2022)
  12. #1104
    Member hectorcairo's Avatar
    Aug 2011
    Hello good morning, would you be so kind as to obtain the data of this VW Passat, I specifically need to know the data of the transponder. Thank you very much in advance
  13. #1105
    Oct 2016
    Slovakia
    VIN: WVWJA83C48P063692
    ImmoID: VWZCZ000000000
    CS: E0AD9D45C15B3A
    MAC CCM: 0DE2
    MAC ELV: A9E9
    MAC ECU: D306
    PIN: 10547
    Power class: 5B
    KEY 0: D2F47716
    KEY 1: 0B6BAF18
    KEY 2: 1193C20C
  14. The Following User Says Thank You to jokir For This Useful Post:
    hectorcairo (3rd March, 2022)
  15. #1106
    Aug 2011
    Quote Originally Posted by jokir View Post
    CS: E0AD9D45C15B3A
    MAC CCM: 0DE2
    MAC ELV: A9E9
    MAC ECU: D306
    PIN: 10547
    Power class: 5B
    KEY 0: D2F47716
    KEY 1: 0B6BAF18
    KEY 2: 1193C20C
    Transponder ID48 o ID46?
  16. #1107
    Oct 2016
    Slovakia
    ID46......
  17. The Following User Says Thank You to jokir For This Useful Post:
  18. #1108
    Jan 2009
    Please need CS from B7 ccm.
  19. #1109
    Oct 2016
    Slovakia
    CS: B24B8C03F32A89
  20. The Following User Says Thank You to jokir For This Useful Post:
    bechiche (13th March, 2022)
  21. #1110
    milane's Avatar
    EU
    hi can you please help me with info for this file
    passat b6
