Page 6 of 82 FirstFirst 12345678910111656 ... LastLast
Results 76 to 90 of 1226
  1. #76
    meteor80's Avatar
    Dec 2009
    Poland
    Hello.
    I need PIN, VIN and CS from this Comfort module.
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  2. #77
    Moderator
    PremierD's Avatar
    Jun 2009
    VIN: WVWZZZ3CZ6E117695
    PIN: 54597
    Component Security Bytes: 29 B2 65 1E 53 64 CA
    That do mate??
  3. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    gwee (1st July, 2015), meteor80 (1st July, 2015)
  4. #78
    meteor80's Avatar
    Dec 2009
    Poland
    Maybe you can also give me MAC?
    F.Kiepski.
  5. #79
    EARTH
    Now only lack decobrir how to find CS.
    PASSAT 2009 DUMP.rar
  6. #80
    filutek's Avatar
    Aug 2009
    Silesia
    Hi.
    This is a file structure comfort. How to calculate the Green Zone?
    Black zone calculate xor 8F19.
  7. The Following 9 Users Say Thank You to filutek For This Useful Post:
    achaccha (15th July, 2015), armpower (8th July, 2015), cscsaba (19th October, 2021), datapage (10th July, 2015), DOUGLASDL (3rd December, 2015), pezao (22nd October, 2015), Vienasisju (10th August, 2016), Weasel3 (8th July, 2015)
  8. #81
    filutek's Avatar
    Aug 2009
    Silesia
    CS please.
  9. #82
    Moderator
    PremierD's Avatar
    Jun 2009
    VIN: WVWZZZ3CZ7E018712
    PIN: 52276
    Component Security Bytes: F3 28 13 5D E6 50 26
    .. As requested ........
  10. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    datapage (10th July, 2015), filutek (9th July, 2015)
  11. #83
    filutek's Avatar
    Aug 2009
    Silesia
    Thanks Premier vin,pin,cs ok ... I counted MAC: DA31108D Forth from GREEN ZONE is calculated xor B549 in the attached post earlier.Where this xor?...hmm
  12. #84
    Quote Originally Posted by filutek View Post
    You achieve nothing from this side. Many have already tried.
  13. #85
    filutek's Avatar
    Aug 2009
    Silesia
    Knowing the pin,cs from comfort can calculate the MAC and manually add to the ECU PPD1.x immo..works good
  14. #86
    filutek's Avatar
    Aug 2009
    Silesia
    The structure of the green zone: assume that xor 11 00 , this: pin 11 11 , MAC 11 00 11 00, CS 11 11 11 00 00 00 11. CS position sequence:
    4AE-1
    4A8-2
    4AC-3
    4AD-4
    4B1-5
    4A9-6
    4B0-7
    All repeated three times.
  15. #87
    Dziwak's Avatar
    Jun 2014
    UK
    filutek
    how do you calculate pin?
  16. #88
    filutek's Avatar
    Aug 2009
    Silesia
    Quote Originally Posted by Dziwak View Post
    filutek
    File post nr.82 pin 52276 ... hex 7981 xor B5B5 = CC34 = 52276 (xorbase 4A6D, xor ELV B549)
    0x577-579: immo status
    0x50E-513: class & brand
    0x5A1-5AC: key ID one
    0x5AD-5B8: key ID two
    0x589-5A0: activ key
    0x514-53D: immo ID
    0x53E-570: vin
  17. The Following 5 Users Say Thank You to filutek For This Useful Post:
    datapage (14th July, 2015), Dziwak (12th July, 2015), Maartinj (13th July, 2015), tawaf111 (25th June, 2019), waldigsi (21st July, 2021)
  18. #89
    Dziwak's Avatar
    Jun 2014
    UK
    Thank you i get it but how you get the xor value ?
    when i try with known dumps cant seen to find the xor value .... sorry or it seems incorect
  19. #90
    filutek's Avatar
    Aug 2009
    Silesia
    Work in progress.........
