I created id48 using tango, and 1 using vvdi2.
Then i scanned for 7th byte.
They came with 00.
And the tango gave error message, but did show the correct pin, and 2 keys.
So good to hear, you figured out what the 7th byte is.
They came with 00.
Hello
Can someone help me calc CS, MAC ELV and PW from VW Passat CCM 3C0 959 433K?
I try the dunt utility and smok license but missing information..
My eprom dump:
Thank you
Mr JohnMarsh, There is something wrong with your dump.
WVWZZZ3CZ6E133985
pin 40714
No tool, gives cs
hello
Can i help someone?
I need PIN code but i don't know how to read ccm dump!
VW PASSAT B7 2011. European
Take out ccm module and read 95320 chip.
Then post dump and you get pin code.
BR
ok to take out, but how can i read it? what cable and programm is needed for it?
Can someone help me, passat b7 ccm i need pin and cs , thank you!
Here you are
mike870 (22nd September, 2021)
Hi, mates !
Can help me with calc CS , MAC ,PIN and any immo data from CCM module Passat CC 2009 ?
VIN: WVWEU73C89E514722 Immo ID: VWZCZ000000000 CS: 7018D086E031A1 MAC: FA91DDEB PIN: 44318 Power Class: B6 ELV: 2942 CCM Status: 6 Key Count: 1 Key1: 1E1DF49B Key2: EB022D73
need help
now my goal is to buy xp-005
who will help?
joroflash (13th October, 2021)
can you help me with info for this file
shotman (25th October, 2021)
hi,
i am trying to learn new (factory new not used) elv (escl) to passat.
pin code should be 62976...
i waited for 255 min and when i write it i get an error message in vcds "controller refused to send a seed"
all timers are at 0
ccm is from the car unedited, keys are from the car.
elv is new..
does anyone have virgin eep file for 3C0959799G ?
read eep attached, and sw to check for pin too.
br,
