Results 1 to 3 of 3
    Default IAW9GV matching help
    Hello group !
    I have problem for matching ecu IAW9GV with instrument cluster ( vw GOL G6 2014 argentine or brazil )
    with VCDS: 01 engine, 16 security access (i have pin code ), 10 adaptation , channel 50 , here VCDS show
    CHANNEL NOT AVAILABLE ! why ?? if pincode is correct.
    somebody can help me ?
    leandroks's Avatar
    Brazil
    U ve to have a matched dumps, u cant match the ecus via obd, get me de part numbers maybe i ve got a set of dumps...
    Hello leandroks, good morning
    ecu: marelli IAW9GV.M 032906032M (chip 95320)
    dash: marelli 5U0920827N (chip 95320) date of production end 2013
    car is model 2014
    if you have paired dump, would be great !
