well done the proper way of doing it.
Where can I find the following file, Kryptview Bin / Firmware is HERE. clicking here provides a range of files which file should I use ?
yep it is the a780, thanks.
Hi Guys please help, i just installed the firmware on a new kryptview a780 and then do a scan. i can see all the channels names but no picture the screen came up with waiting for code update, i can get bbc1 ,2, itv,ch4 ch5 .I left it over 24 hrs and it still say the same. thanks in advance
hi m8, which firmware did you flash it with?
where did you get it?
can u go into
1. menu.
2. installation.
3. s/w update.
if s/w update option is available then start it and post back reuslts....
Some help please? (went through all 13 pages. Not sure about this..)
Just got a A780 box yesterday and found that both my home laptops don't have 9 pin serial port
Can I go to my friend's house (he has a desktop pc with serial port and internet. But no cable TV) and do the firmware update? If it's possible, then at which step I should stop (Just after "Download success" message or after final step in the tutorial "Once finished let the box reboot")
Many thanks in advance
if you have a spare usb stick,download the loader and fle from downloads above and put it on the stick,when over at his place plug the stick into pc and it should see it,follow the tuts for flashing and remember box has to be off first before pressing download,then box powered on.all you need to do is flash it at his place thats all,you can scan at your place and have lan removed.
http://www.digital-kaos.co.uk/forums...firmware-1491/
do i need to have the box on when i flash it? as in plugged into the main socket
keep the box turned off until you press download on loader then quickly switch kv on to initiate the flash process
the link for the Bin file on the 2nd post does not work. any solutions
You will find it here:
Bin File
Can't get download Tool to work any help please driving me mental
