Results 1 to 15 of 17
    Mar 2009
    Default DB500S Won't display some channels after doing a transpod. scan :\
    Hi guys,
    I updated my dbox 500s with Nabilo Dakrstar . After doing a transpod. scan it won't display some channels of the Nova Greece provider nova
    IE:
    Service Name
    Boomerang
    Chasse & Peche
    E! Entertainment
    GAMES
    Mad Radio
    Nova Promo
    novacinema3
    novasports highlights
    novasports4
    novasports6
    Playboy TV
    Private Spice
    The History Channel
    All those channel's won't show up - I even tried a manual search using the frequencies but nothing.
    I don't want to access them - I just want them to be displayed in the list. What could cause this problem?
    Thank you
    Mar 2009
    (I even tried getting a hotbird satellites.xml file from that satellites-xml website but still nothing)
    V.I.P. Member opsmonkey's Avatar
    Nov 2008
    var/etc
    you say you have only done a transponder scan.. you do know not all the Nova channels are on the same transponder.. have you tried a full scan of 13E.??
    Mar 2009
    Quote Originally Posted by opsmonkey View Post
    Yes, I did a FULL scan on 13E and found around a thousand of services but those specific channels are not listed. Thats when I did try a manual scan using the frequency of the specific channels but still no luck. What could be causing it ? :\
    (btw I am using DarkStar for my DB500S. I have to mention here that doing a scan using a hotbird xml file from satellites.xml generator displays some more channels that the default scan with darkstar does not. But, in both cases, the channels I mentioned above will never show. I only remember seeing them once back when I first bought the dbox. Since then they disappeared)
    Nov 2008
    var/etc
    must be an image problem mate.. i've just done a full rescan of 13E and got all those channels using Gemini 4.2
    Try a different image if you want them
    Mar 2009
    Thanks for your replies mate. Which image would you suggest ? I know I cannot install Gemini as it will kill my clone DB500s :\
    Nov 2008
    var/etc
    You can install Gemini 4.2 onto a clone box.. the kills came in v4.3 and above..
    DK v1.1 is a good one
    have a look in here
    http://www.digital-kaos.co.uk/forums/dlcat-images-2/
    Mar 2009
    have a look in here
    Digital Kaos - Downloads - Images
    Ok ill try that one and see if there're any results :-) Thank you
    Mar 2009
    Ok i am back :-)
    After experiencing some problems I managed to install Gemini 4.20, but still, those channels mentioned above do not show up in the channels list :\
    The only time I saw them was when I did my first scan when I first received the receiver with it's initial image (cant remember which it was though - my DB500s is a clone if that helps?).
    A few days after receiving the receiver I flashed it with Darkstar and since then those channels are a no-show. Could it be that some settings of darkstar which caused the channels to disappear are still in the box, so, even after flashing with other images those channels are still a no-show ?
    Because I cant think of any other reason why the channels do not appear in the channels list:\
    Nov 2008
    var/etc
    No.. assuming you did the flash erase no Darkstar settings are left..
    Sound like it could be a tuner problem.. unless you havent made / downloaded the satellite.xml file proprerly..
    wipe the satellites.xml file located in:
    var/etc
    replace it with this one (a copy of mine), unzip the file using WinRAR and extract the .xml file
    Try a full rescan of Hotbird and any other satellites you view
    See if that sorts it out
    Mar 2009
    var/etc
    arghh still no luck
    Nov 2008
    var/etc
    your tuner sounds dodgy
  13. #13
    Mar 2009
    opsmonkey: I tried the tuner at another place and all the channels work fine.
    Trying it @ my place, only some of them work.
    So my question now: Could it be the LNB wire/cable not making a good contact with the receiver?
    Or could it be a problem with the satellite dish/lnb on it?
    Thank you
  14. #14
    Mar 2009
    (Oh need to mention here that all the channels that work have a SNR of around 80% + .. whilst the ones that dont work have an SNR of less than 80.. usually around 70-72.. How can that be fixed?
    thank you
  15. #15
    V.I.P. Member westkill's Avatar
    May 2008
    Quote Originally Posted by meddi83 View Post
    Thank you
    i think youve answered your own question m8
    check it all from the
    dish>lnb>cable>reciever
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
