With BDM as far as i know it will not pick up on the counter . i thing only on OBD the counter picks up .
i am looking for a bit of info if any one can help
i am looking to bypass the flash counter on ecu like med9.1 edc16 and med17 edc17
if i flash ecu with bdm will it still pick up the the ecu has been reflashed on the counter ?
The information I share is purely for research and educational purposes I can not be held responsible for any damage to devices or any injury caused by malfunctioning devices
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
josecuervo (25th June, 2014)
True, bdm programming doesn't increment counter.
Regards,
josecuervo (25th June, 2014), PierreTheron (17th July, 2020)
bdm or bootflash does not increase counter. only obd flashing. counter is stored in e2p. make backup of original e2p and you can reset counter to ori value anytime you like.
genuine tools owned: too many
genuine software owned: have lost count
thanks guys will go back and compare files of the e2p before and after i program the ecu with the obd port and maybe can work out how it stores the values and return it back to 0 after the flash might help some other DK peeps in the future
Quite a few values will change, not just the flash counter. I've done the same and worked out the flash counter on VAG EDC16
Tools exist to reset the counter obd eg powergate, fgtech
I've tried fgtech v51 to reset and did not work for me, kess china worked, but only worked on edc16u31, edc16u34 did not worked. And it takes ages to download and upload the file. The best in my opinion, it's to change on e2p
guys, sorry for bringing this topic alive again but Im facing some problems with VW dealers (warranty).
they are looking for flash counter and canceling cars warranties. is there a way to solve that writing via OBD ? (using CMD flash)
most MED17 and Simos ECUs.
I believe kess can reset flash counters but not sure which models & also cmd
it is best to email the companies to see if the ecu's you want doing are support flash counter reset .Then find a local tuner who has kess/cmd ect to reset for you.
like people have already said counters don't advance when bench flashed only over obd ,so most choose this route or can use there original e2p file and write it back if they need to.
you country probably check the calibration ID or Calibration Verification Number of the ecu also to confirm authenticity of the software .
flash counters can go up when a dealer flashes your ecu so i would say they are more likely to check if the CVN doesnt match as theyre looking for a non oem file ,this can be corrected ask Anton his advice on this !
