Results 1 to 9 of 9
    Oct 2010
    Bucharest
    Default DPF off Audi A8 , ASB engine
    Hello ,
    I was made dpf off for an Audi A8 with ASB engine , 232 CP (171 kw ) , 3000 cmc , and after made dpf off , the cruise control system doesn't worked anymore . I was load the original file and cruise controls worked again . What happen ? What is it wrong ?
    Anybody can help me ?
    Best Regards ...ASB.rar
    bad software solution..
    Oct 2010
    Bucharest
    Why ?!
    Can You Help me ?
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Changed file is a mess. Change ori file. 1D1ADC 00256 to 00000. Job done.
    Oct 2010
    Bucharest
    On my map in the adress 1D1ADC the value are not 00256 ?! Why ?!
    Thank You Verry Much ...
    Best Regards ...
    Mar 2011
    Quote Originally Posted by Corneliuss View Post
    Best Regards ...
    16 bit decimal view. Your file. 1D1ADC is 00256. change to 00000
    Oct 2010
    Bucharest
    Hello ,
    I can't succeed to find that value at that adress .
    Can you show me how you does that ?
    Best Regards ...
    gwee's Avatar
    Dec 2012
    unknown
    you need winols
    Jul 2012
    Quote Originally Posted by Diagnosticated View Post
    the address is already zero.
    this is not enough
    This version has a combined solution.
    Version fap off corneliuss user needs other fixes but the switch is ok
