1998 i guess desolder job.
smokeygc (26th June, 2014)
M3.8.3 can?t be read, just write if you google you?ll find an original file from these ECU
I have the original files, VW golf 1.8T 150HP 06A906018R 0261204673 358109 & VW golf 1.8T 150HP 06A906018R 0261204673 359591,
I have also a second unit (ECU), just in case for backup.
But how should i do with the IMMO? is it going work with no problems?
thanks for the support!!
You should do the immo in case if you change the ecu , i other case just mod the ori file and write it over obd that all .
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
