Results 1 to 3 of 3
    Dec 2010
    Default Astra H Z19DT P1125 DTC Remove
    Please help removing Throttle valve DTC P1125, EDC16C9,
    0281012549
    Z19DT
    Thanks in advance!
    smokey08's Avatar
    Essex, UK
    DTC P1125 removed.
  3. The Following User Says Thank You to smokey08 For This Useful Post:
    xdamdamx (29th September, 2015)
    Jul 2012
    Quote Originally Posted by smokey08 View Post
    DTC P1125 removed.
    dtc file your 1125 off seems ok I do this work manually as you perform this procedure ..
    I counted 9 dtc 1125 9 switches .. this seems to be the solution but there are other 1125 before you checked?
    I'm curious to know if it is enough to rule out or you have to put to zero also address c8206-c824c but they seem off the table dtc!
