Results 1 to 14 of 14
    korrni's Avatar
    UE
    Default Fiat Grande Punto 1.3MJD6F3.PI/HW04P/3641-PI90 75hp no start after crash
    Hi there, I have a 2009 Fiat Grande Punto which was involved in an accident, resetted the airbag computer, rearmed the FIS, no errors on the ECU neither on the BSI, but the car won't start, the fuel pump does not work, checked the fuses and wirings, all ok. Could you send me a clean dump of the eeprom? the ecu is a MJD6F3.PI/HW04P/3641-PI90
    G PUNTO 75hp UEGO SM2 7gcsdpa9j. Dump of the eeprom ST95320 in attach. Thanks a million!
    fiat_st95320_ori.rar
    SOLVED_CHECK MY #10 POST
    super jumbe's Avatar
    Livingstone
    Have you checked fuel pump cut off switch on left hand side under the glove box, usually after the impact the switch gets deactivate to stop the fuel.
    metercar's Avatar
    May 2011
    Argentina
    as I solve the problem?
    on a rich or poor discussion - PL & SP blood - only on bench
    korrni's Avatar
    UE
    Actually this model didn't have fuel inertia switch fitted, to re-arm the FIS I followed the "ignition on, indicator right, left, right, left, ignition off" procedure. The problem was in the ecu eeprom dump, which blocks the fuel pump relay and does not command the injectors.Thanks and credits to 3in1san , who sent me a virgin dump of the st95320, the car started, after I only had to re-write the injector codes. Thanks again, mate, and thank you for your replies!
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    i have a similar problem, can you send me virgem dump? after that need to reprogram immo?
    korrni's Avatar
    UE
    There you have it, no need to reprogram immo!
    Pass in PM!
    fiat_st95320_virgin.rar
    !!!SEARCH POST #10!!!!
  7. The Following User Says Thank You to korrni For This Useful Post:
    jjrp255630 (2nd July, 2014)
    Member jeffbih's Avatar
    Apr 2012
    Bosnia & Herzegovina
    Hi korrni can I have pass for this file, I have a similar problem...
    bulanbulanov's Avatar
    Italy, Abruzzo, Teramo
    Default This file is for all MJD 6F3.XX.......
    --->>>Attachment 270659
    you must rewrite the injectors codes and all ok .....
  10. The Following User Says Thank You to bulanbulanov For This Useful Post:
    jeffbih (29th July, 2014)
  11. #9
    Apr 2012
    Hi bulanbulanov, I dont have communication with ecu at all with your file, do you have another one...
  12. #10
    korrni's Avatar
    UE
    Fellow friends on DK, all posts with st95320_virgin, including mine, are rubbish, because the mjd6f3 ecu keeps the keys in the eeprom and, if you will try to write a "virgin eeprom solution" exists a great risk that your ecu flash corrupts and the car won't be able to communicate with the engine control unit anymore. Back then I fell in the same trap, my car started, but only once, so I thought it was an ecu hardware problem. I bought a brand new second hand ecu, wrote the "virgin eeprom solution"+the original flash, and guess what, the same situation, not even communication with the engine control unit.
    So, I kept the original eeprom, search a Flash file from a car that wasn't involved in an accident, wrote it, and voila, problem solved. Believe me, it is 100% tested, my customer still uses his Fiat. I know I am a junior member and my words are not so, let's say, so reliable , but if you will search through posts with people who actually wrote "the virgin eeprom solution", you will see that are a few that weren't able to communicate anymore with the engine control unit. So, original eeprom+a flash from a car that wasn't involved in an accident it is the real solution.
    Greetings.
  13. #11
    leandroks's Avatar
    Brazil
    When ignition on the indicator light on dashboard is blinking???
  14. #12
    korrni's Avatar
    UE
    To reset car operation, follow this procedure:
    turn the ignition key to MAR;
    activate the right-hand indicator;
    deactivate the right-hand indicator;
    activate the left-hand indicator;
    deactivate the left-hand indicator;
    ❒ turn the ignition key to STOP.
  15. The Following User Says Thank You to korrni For This Useful Post:
    credoline (18th January, 2015)
  16. #13
    Oct 2016
    Hello Korrni
    I have similar problem i read mpc eeprom and flash after write only flash back car won`t start ( start 2 seconds only and cut off )
    I checked chksum for flash are ok
    can you help me with this what to wirte to get car started
    i did not touch eeprom or mpc and i writed back original read flash
    Fiat 500 1.3 mjt 2008
    ecu 6f3.b1
  17. #14
    Oct 2016
    Hello Korrni
    ecu 6f3.b1
