Results 1 to 8 of 8
Thread: New problem
    Top Poster hammers2009's Avatar
    Jun 2012
    Default New problem
    Got a skybox f5s and I put a USB in there not reading it tried a few no luck is this a problem with the box if so is there any other way to update the channel list ?
    Hadron's Avatar
    Nov 2012
    E. London
    Does it recognise the USB stick at all, or is the "upgrade by USB" option still greyed out?
    Jun 2012
    Yeah I put the USB stick in there and normal you will see USB been inserted you don't see that + the option is still grey so you can't click on it
    Member The Reaper's Avatar
    Jul 2008
    UK
    Try inputting by remote the code 6666 this should high light the grey and allow you access.
    Reaper.
    "Everything I do is legal---I think."
    super jumbe's Avatar
    Livingstone
    Some time you may need to format USB with fat32 to recognise.
    ar5ena1
    Guest
    Sometimes you need to turn the box off and on whilst the USB is plugged in for it to work
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by hammers2009 View Post
    Does the USB stick show up OK in your pc or laptop?
    If it does, you could try reformatting it again to FAT32.
    Mar 2013
    Or try using another USB
    Had this experience with mine and l tried another memory stick and it was fine
    Previous stick was on FAT32 as well - for some reason it was recognised by couldnt update the channel table
