Page 42 of 45 FirstFirst ... 32373839404142434445 LastLast
Results 616 to 630 of 664
Thread: ETSmart script!
  1. #616
    Rerouter's Avatar
    Jul 2014
    Australia
    Good to see people getting familar with this stuff still, If anyone wants help writing there own scripts, I can assist (Literally wrote the guide on this stuff),
    Perun main thing I would say is use consistant indentation, makes things easier to maintain, you know your free to change the messages up to your own native language if your more comfortable with that, anything in quotation marks can be safely changed without any risk. all of it was in russian before I re-wrote those templates
    Also the milage can get above your max value, but you need to find some high milage dumps to resolve the why
    A file for feedback, This is all that is asked on this site, Did it work? what value appeared on the dash? maybe some photos or a power-up,
  2. The Following 8 Users Say Thank You to Rerouter For This Useful Post:
    brend (22nd February, 2021), FxShaw (14th February, 2021), Johnner (8th February, 2021), jomberykaso (8th February, 2021), neospeedo (8th February, 2021), Niaz (14th March, 2021), teerak2uk (8th February, 2021), zckariya70 (8th February, 2021)
  3. #617
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Quote Originally Posted by Rerouter View Post
    Happy to see u again ,Welcome back to DK ..................
    Nothing will remain in this World , Everything will come to END!
    THINK POSITIVE NOTHING IS IMPOSSIBLE
    Please do not spam by PM asking for help. Use forum, that is why we are here.
  4. The Following 3 Users Say Thank You to zckariya70 For This Useful Post:
    DashProg (6th August, 2022), Johnner (6th March, 2021), neospeedo (8th February, 2021)
  5. #618
    ElectroRadar's Avatar
    Mar 2018
    Mexico
    Good morning, everyone, can you help me make a mileage calculator to modify the odometer of a 2009 ford lobo with eeprom 24c16
  6. #619
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Quote Originally Posted by ElectroRadar View Post
    2396xx kms?
  7. #620
    Mar 2018
    Mexico
    If this is but it is in miles your answer is approximately 239677 miles
    Can you help me with the calculation please to be able to modify this value
  8. #621
    Rerouter's Avatar
    Jul 2014
    Australia
    Usually Visteon 128 Algo, 0x798-7AB, so you should just have to tweak the start and stop locations of an existing visteon script.
    Technically the same as a F150 calc,
    And yes 239667 is the value in that file.
  9. The Following 2 Users Say Thank You to Rerouter For This Useful Post:
    Johnner (5th March, 2021), neospeedo (1st March, 2021)
  10. #622
    Mar 2018
    Mexico
    Do you know where I can get this scrip for the f150 2009 and please
  11. #623
    Aug 2013
    Here you go, easy as pie
    I am making one for Fortuner/Hilux Innova 2016 and up, is there a need for checksum so no freezing?
  12. #624
    Mar 2018
    Mexico
    Can you help me calculate this script, it does not give me the mileage and it does not modify it either, it gives me other values
    Program Prog1;
    var
    Code,Code_1: string;
    KM: Integer;
    Procedure ReadKM;
    begin
    AddMsg('F150-Lobo km');
    Code_1:=inttohex(GetByteHexEdit($798),2)+inttohex( GetByteHexEdit($799),2);
    Delete(Code_1,1,1);
    Code:=IntToStr(StrToInt('$'+ Code_1)*128)
    AddMsg('KILOMETRAJE ACTUAL: '+ Code+' km');
    MsgBox('KILOMETRAJE ACTUAL: '+ Code+' km', 'KM ACTUAL', MB_OK);
    end;
    procedure NewKM;
    var
    n,new_KM: integer;
    n1: String;
    begin
    SetProgramModifiedOnly( true );
    if InBox( 'CAMBIA EL KM', 'ESCRIBE EL KM DESEADO', code ) then begin
    end;
    if StrToInt( code )> 999999 then begin
    MsgBox( 'Enter 000001-999999 Code', 'Error', MB_OK );
    exit;
    end;
    n := StrToInt( code );
    new_KM:= (16384 xor(n/128));
    n1:= IntToHex(new_KM,4);
    SetByteHexEdit( $798,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $799,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $79C,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $79D,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7A1,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7A2,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7A4,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7A5,(strtoint ('$'+n1[1]+n1[2])));
    SetByteHexEdit( $7A8,(strtoint ('$'+n1[3]+n1[4])));
    SetByteHexEdit( $7A9,(strtoint ('$'+n1[1]+n1[2])));
    RefreshHexEdit;
    if MsgBox( 'PROGRAMAR?', 'CONFIRMAR', MB_YESNO ) = IDYES then begin
    ProgramDevice;
    VerifyDevice;
    ReadKM;
    end;
    end;
    begin
    AddDeviceGroup( 'FORD ', 'SELECCIONAR' );
    AddDevice('F150 2009', '24C16', 'FORD ', '24C16' );
    AddAction( 'Read KM', 'ReadKM', 'F150 2009' );
    AddAction( 'New KM', 'NewKM', 'F150 2009' );
    end.
  13. #625
    Aug 2015
    Try this one.
  14. The Following 5 Users Say Thank You to perun750 For This Useful Post:
    ElectroRadar (28th February, 2021), janushaan (24th June, 2021), Tolik48 (3rd November, 2021)
  15. #626
    Mar 2018
    Mexico
    I thank you but this file as I execute it I use scrip for upa
  16. #627
    Rerouter's Avatar
    Jul 2014
    Australia
    Electroradar, as I am not as familiar with UPA's scripts syntax (believe its based on BASIC), if you could translate it to something closer to C Language or psudo code, I can help go over it,
    At a minimim it looks like its missing stuff, both from the read and expecially from the write,
    From the text its for a F150 24C16, that should be a Visteon 128 algorithm the 798-7AB variant,
    If you take a look at what perun supplied, with the big 3 stage lookup table at the end, that is something your going to need to translate to properly set these files within 1500km of what you type in, for ETSmart Scripts, everything after OnShow is the read section, everything after OnApply is the write section. Implementing this will get you within atleast 128km or 64km depending how you implement it, There is more to be done if your willing to work it out to get it to 1km, or to read / write higher than about 200,000km
    Edit, for the read, I can atleast give a rundown of what is supposed to happen. Take 0x798, shift it left by 4 (or times by 16, for the same result), then add that to the 0x799, right shifted by 4, then anded with 0xF
  17. The Following 7 Users Say Thank You to Rerouter For This Useful Post:
    andrym3 (25th March, 2021), bandus (2nd March, 2021), ElectroRadar (2nd March, 2021), Johnner (5th March, 2021), jomberykaso (2nd March, 2021), maremuruk (3rd May, 2023), neospeedo (1st March, 2021)
  18. #628
    Mar 2018
    Mexico
    Le agradezco su interés Redirior no estoy familiarizado con este programa ETS, se ve que es muy bueno, estoy más basado en Pascal ya que Upa maneja diferentes formas de hacer algoritmos y lo que necesito es calcular más de 400.000 km que ocupo para aumentar el kilometraje y no para bajarlo pero los algoritmos no me dan para modificar bien el valor, el valor que lee el algoritmo está bien al cambiarlo hace que sea incorrecto.
    Ahora si quería que el valor se diera en Km ya que este valor se da en Mile y ocupo que el resultado está en km. Gracias, ya entendí el guión de ETSmart y logré hacer el guión para Ford Lobo 2009 con eeprom 24C16, también adjuntar la conversión de millas a kilómetros, así que ahora lees kilómetros y escribes kilómetros, saludos a todos y gracias por las sugerencias posteriores intentaré continuar con el scrip upa
  19. #629
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    [QUOTE=ElectroRadar;4077516]Le agradezco su interés Redirior no estoy familiarizado con este programa ETS, se ve que es muy bueno, estoy más basado en Pascal ya que Upa maneja diferentes formas de hacer algoritmos y lo que necesito es calcular más de 400.000 km que ocupo para aumentar el kilometraje y no para bajarlo pero los algoritmos no me dan para modificar bien el valor, el valor que lee el algoritmo está bien al cambiarlo hace que sea incorrecto.
    F150.jpg[/QU
    Ask ur solution in only english , Not in other language...........
  20. The Following 2 Users Say Thank You to zckariya70 For This Useful Post:
    gmb45 (3rd March, 2021), PremierD (3rd March, 2021)
  21. #630
    Mar 2018
    Mexico
    Good morning zckariya70 I published the solution in Spanish because I am from Mexico but if any member occupies that I explain it in English or will occupy it in English I will gladly support you in the solution in English greetings and thanks for the help greetings from MEXICO
