Results 1 to 5 of 5
    Fec001's Avatar
    Default VAG EDC17CP14 boot mode with galetto 2
    Hello!
    Can you give me a step by step instructions for put this ECU boot mode with galetto?
    I wired ECU, give 12V adapter to galetto solder 1000ohm resistor to boot pin. Choose the SAK-TC1796 Boot mode.
    When I click connect after galetto only asks me to remove and give feeding to ECU before continue. Nothing about when connect the boot wire to bootpin like older ECUs like MM ST10xx or Siemens infineon C167
    Jun 2013
    EU
    Just follow image and on screen instructions.
    Click connect on fgtech sw as you did, then power on the ecu with the bootpin connected and hit OK on the dialog.
    Just that.
  3. The Following User Says Thank You to morgano For This Useful Post:
    Fec001 (2nd July, 2014)
    Fec001's Avatar
    I did that and after some time it asks the same again " Remove and give feeding to ECU before continue"
    The resistor is only 980ohm, is that could be problem?
    EDIT:
    Solved. In my PDF CAN Low is seems yellow. I saw on yours, it is orange.
    Jun 2013
    EU
    Yellow is L-Line
    Jul 2018
    Norge
    I have the same problem, can anyone help what should be put down?
