Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Nov 2009
    Default Fgtech galletto 4 v54 chinese, new win install ?
    Hello all..
    I just a new galletto 4 v54, but after install it wont start !!
    Must i do a fresh install of windows xp or is there an soloution to remove the old fgtech from system totally ?
    //Dennis
    Jun 2013
    EU
    Actualize driver with V54 one.
    Nov 2009
    Quote Originally Posted by morgano View Post
    Hello morgano.
    What you mean?
    I just installed the software and driver, but not starting
    //Dennis
    Apr 2014
    if you had a older version already installed on yr pc then you wont be able to install newer version...#
    you have too first remove existing(older version)and then install newer version...
    good luck..
    Apr 2014
    also if you have installed vcds or similar program which is using Ftdi drivers then you could damage your new toy...by installing galletto software on same pc..
    Jun 2013
    EU
    Quote Originally Posted by Shemek View Post
    good luck..
    This is not stricltly true, i have V51, V53 and V54 working fine on the same machine and same partition. Just different folders
    Quote Originally Posted by Dennis- View Post
    What you mean?
    Just what i say, uninstall old driver and install V54 one. Then probably usbfix and sw should run. Of course if you have installed it in C:\FGTech in other folder will not work as is.
    Nov 2009
    Hello again.
    The usbfix i have is for v53, can i use that one ?
    //Dennis
    Nov 2009
    I tried now the usbfix and now it says please make renewall .
    What is wrong now ?
    //Dennis
    Jun 2013
    EU
    What OS are you runing the software in? XP or Win7?
    Regards,
    Nov 2009
    Problem solved !
    I run win xp sp 3.
    this is what i did: Clean all fgtech files even the register, put clock back 20130101 and copy the setup file to desktop.
    Installed the software and driver, after that i run usbfix and run the installation one more time ( whithout uninstalling fgtech ), Now everything working !
    This is how i did and hope it will help others with same problem and without install windows again.
    Thanks to all that helped me.
    //Dennis
  11. #11
    Aug 2013
    I have V54 and when installing FGTECH Galletto edited v1.0, it gets stuck at get_hw.exe and then get a Data Error (Cyclic Redundancy Check).
    Any idea?
  12. #12
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    try this download m8
  13. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    duplikeytor (7th August, 2016)
  14. #13
    Aug 2013
    Quote Originally Posted by smirnoff_rules View Post
    Thank you very much Sir!
    I will try and report back.
  15. #14
    Aug 2013
    So I followed the instuctions and installed it on a windows 7 system. The first installation went smooth and completed. I opened the application and got the message where it stated it's registerd to dragan. Then I installed it again and went smooth. Now when I start the application, nothing happens. I restarted and same thing. Then I installed the Win7 installation file, and installed properly but when I try to open, nothing happens.
    Appreciate the support!
  16. #15
    Mar 2008
    birmingham
    look in taskmaster and stop any ebdo files running and see if that helps
    did your driver install on your fgtech ok too
    seller from aliexpress sent this last night . bigger exe file to ?
