Results 1 to 15 of 30
Hybrid View
    Jul 2009
    Quote Originally Posted by samiko View Post
    Please help in installing a dongle Vag K Can Commander 2.5
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Hi Does this install the files to a dongel or make the program not need dongel ?
    Jun 2009
    Quote Originally Posted by Chadder View Post
    My interface 1.4 I was trying program 2.5 +Dongle well unsuccessfully.Dongle oneself me unsuccessful installed.
    Please help.
    Jul 2009
    Please stick for the moment to the V1.4China version, that came with the cable, or is referred in the other thread abouth this interface. Just for the record, i'd advise you to re-read that thread completely, as i and others advised people with trouble, getting this cable to work. A quick downloadlink for you that will help you with getting the stuff to work :
    This works with the black cable withouth the extra supplied usb-key-stick (Dongle). I can't confirm this if it also works with that version of the cable, as i don't own that combo or heard success-stories that it indeed was functional with it.
    First of all, try a freshly installed pc, with windows XP or lower operating system. XP works 75% of the time perfect.
    And remember, to NOT put the OBD-side of the cable already into the car's OBD-port, while starting up the software. This mostly will give the problem as the software will not open up.
    And DO NOT install that DOGdriver for starters. It will only create problems if you DON'T got a usb-key-stick (dongle) with the cable and the software supplied.
    Hope this helps getting you up and running.
    Regards,
    P@z
