Results 1 to 3 of 3
    Jul 2014
    Default USB Loader Error: WBFS hd sector size doesn't match
    Hey there. I've been trying to figure out how to play backed up games off a 1TB USB hard drive for the past couple of days without much success. After fiddling around with a bunch of different settings, programs, and different custom IOS installs and the like, I still haven't been able to make it work. Currently, if I try to use USB Loader GX, it kicks me back to whatever loader I used to get there (HBC or Wii Menu) shortly after trying to run any game except Wii Sports. I finally got a lead after trying cfgLoader, where it told me "wbfs error: hd sector size doesn't match". As I understand it, some hard drives aren't compatible with these loaders due to the sector size being too large or something. If that's the case, then I'd like to know what to look for to find a drive that would be compatible with it. I also tried a 4GB USB flash drive, which also gave the same error. Both drives are formatted as FAT32. I tried for a long time to get them formatted as WBFS, but I think due to the sector size issue, it won't let me do that. (And I read somewhere that using WBFS is outdated and unnecessary anyway.) I've already copied my Wii library via USB Loader GX to the hard drive, and it recognizes the games without any trouble. Just can't run any of them besides Wii Sports, which is odd, because if the hard drive wasn't compatible, I would think none of the games would work.
    As I've dug around through here, I've noticed it's common practice to use sysCheck and post the results so people here can easily see what I've installed, so I've put that below. I've tried loading games using a number of the custom IOS's installed, but none of them seem to work (249 is the default used). I'm not sure what else to do, so if there's anything else I can try short of buying a new hard drive, please let me know. Thanks.
    sysCheck v2.1.0b13 by Double_A and R2-D2199...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Priilaoder installed
    Homebrew Channel 1.0.0 running on IOS58
    Hollywood v0x11
    Console ID: 36115432
    Boot2 v4
    Found 103 titles.
    Found 55 IOS on this console. 3 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[75] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2014/07/03.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    There are a couple of sites that show USB Compatibility List.
    http://wiki.gbatemp.net/wiki/USB_Dev...atibility_List
    I see nothing wrong with that sysCheck.
    I've always used WBFS Manager and it never failed with any game I have.
    Wii Sports is a strange game you have to play the original game disc once so it makes a saved file then it will work, you can't copy a friends saved game file. There are crack files for this game if you Google them.
    Keith
    2010 Golf GTD (170)
  3. The Following User Says Thank You to Keithuk For This Useful Post:
    Pete993 (5th July, 2014)
    Jul 2014
    Thanks for the information. I tried a different drive and it seems to work fine now. Suppose the first one just isn't compatible.
