Results 1 to 4 of 4
    speedy100's Avatar
    Athens
    Default OPCOM compatibility
    I have OPCOM ver 1.39 and would like to know if software version 2010 is compatible with it.
    Thank You and best regards!
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
    igorr's Avatar
    Aug 2010
    I use 2010 software with 1.39
  3. The Following User Says Thank You to igorr For This Useful Post:
    speedy100 (7th July, 2014)
    speedy100's Avatar
    Athens
    Quote Originally Posted by igorr View Post
    Thank You Igorr !
    I have this problem with OPCOM 1.39 and i need some help as I am stuck...
    In Opel Corsa D 1.2 gasoline (Z12XEP) 2008 model, OPCOM can not communicate with CAN Dash (IPC) and Airbag (SDM) modules. Are there any special communications parameters to change in order to overcome this problem or any other idea?
    Best regards
    May 2014
    it seems that your interface might be faulty. try usig the software from here and see what happends. https://mega.co.nz/#!8II3wLKb!_oxvdv...LEjFHkTpLIRrfw . the archive might seem having a virus but is a false positive. there is no virus
  6. The Following 5 Users Say Thank You to mcmagic For This Useful Post:
    abouhouda (10th October, 2017), Col19 (13th November, 2019), ecufix (8th July, 2021), goalfocus (19th April, 2016), speedy100 (5th August, 2014)
