Results 1 to 15 of 19
    Jul 2012
    Montreal, Canada
    Default TOYOTA USED SMART KEY REGISTRATION
    Hi everybody,
    I have a 2009 Toyota Corolla with smart key and AVDI with Toyota commander. Is there anybody who has experience how to add one more USED key to the car?
    Jan 2014
    How much Freq for Original keys if it is 315 then you can add Used keys if 433 then only new keys . yes used possible in 433 but must be remove ID box
    i think so you have 433 so you cannot add used key until you reset id code box . if 315 ok you can reset with Avdi see instruction thats all
    gwee's Avatar
    Dec 2012
    unknown
    good to know that, thanks
  4. The Following User Says Thank You to gwee For This Useful Post:
    bearheroes (1st June, 2015)
    Jul 2012
    Montreal, Canada
    Yes my key is 433. There is function in AVDI to reset ID box it takes about 12hours but what after reset?
    gwee's Avatar
    Dec 2012
    unknown
    there is no such thing as 315 can use and 433 cannot use !!
    all are the same. done many many many.... don't understand why false info is posted here
    have been using USED smart key from day one, never once open dash
    I think the used one can reprogram when lost keys
    and then adding new one.
    but many time tried to add used one with nothing result.
    Jul 2012
    Montreal, Canada
    Any idea if I go with ID BOX reset is there any chance to program the keys after?
    Jan 2014
    Quote Originally Posted by 112005 View Post
    100 % man , you can add used key after reset id box but as you know Khalej always problem when are key lost
    avdi can not reset until you remove id box , you have to reset both by avdi dump function
    smart box and id code box or you can make backup keys by avdi with tpx2 I think you knows that already
  10. #9
    Jan 2014
    Before you going to open id code box please better ask Gwee
    according Gwee saying my info false , yes I am agree with gwee because I am not expert in Toyota only I knows little
    but what I knows I share . Also I am agree with gwee it is possible to add used key
    inside dump to smart box . But didn't try before I always make reset to add used keys
    but please if your car freq 433.2 then you should try with 433.2 not with 315
  11. #10
    siyadk's Avatar
    Dec 2012
    cars outside US...Impossible to add used keys without removing id code box
    However, IT IS POSSIBLE to add used keys BUT it is only known very few people or members here, it is highly classified information!! so now for time being for you, you cannot add used keys to cars which are outside US(where US:J2534 laws does not apply!!)
  12. #11
    ray-ray's Avatar
    In USA 315 freq. is reusable by resetting 16min. With drivers door open and don't push to start the ignition at all. Durning that 16min wait I replace the proxy battery and check the pcb board to make sure they match.
  13. The Following User Says Thank You to ray-ray For This Useful Post:
    gwee (11th July, 2014)
  14. #12
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by ray-ray View Post
    even japan or europe region, some models below 2009 are possible to do the 16 min reset, but always a risk to corrupt the esl.
  15. #13
    Jul 2012
    Montreal, Canada
    So finally the car is in Canada, MY 04/2009 and the smart keys are 433MHz. AVDI with TN005 (toyota special function) authorization has a option to reset ID BOX by LIN bus (you don't need to remove the dash). My question is which way to go, erase the keys (15 min) or ID-box reset by LIN bus (12 Hours)?
  16. #14
    gwee's Avatar
    Dec 2012
    unknown
    try 16 mins reset, otherwise buy new key
  17. #15
    Jan 2014
    Even You erase all Keys < You Cannot add used Smart key 433 mhz Keyless Via Obd . and Never Try to Erase Keys in 433 mHZ There is 99 % Risk . Sometimes After Reset Keys when you try to Add used key system Blocked car stoop . no more ignition On .Better Option Buy new Key Program that 5 min job with avdi , Full Free Tension
