Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 53
  1. #31
    Oct 2012
    great to
    beltronics...here are the files with cecksum ok...must work
  2. #32
    Oct 2012
    if not work ,we thimk that you do not read well the orig file...sommes errors with galletto...try on bdm100.mpps,or programmer...
  3. #33
    Jun 2010
    i dont know how to corect cheksun
    betrescudan i trayed your file good acceleration but not from stop
    from stop 0-100 12 sec
    i have just galletto v54
    can u learn me how to cheksum
    i have problem egt sensor 2
    and lambada ...
  4. #34
    Oct 2012
    cecksum is ok....you have automatic gearbox...ai said you...can,t accelerate with these gearbox from 0%load to100% load because you risk broken the clutch and gearbox...need the tune working from 45-50% load to the end....and from 1400-1500 Rpm to the end...finaly,to tune your car,must modif a ori file without any dtc error....so,you can use these mod like he is and try reppair the lambda and sensor,or cancel mechanical the FAP(DPF),and then the EGR and FAP(DPF )from ecu...and retry
  5. #35
    Oct 2012
    theoretically,the cecksum is automatically calculated by the prgram for tuning...for somes cars can,t be calculated by titanium...so in this case,must help from another who use winols...winols can see if cecksum is ok...and reppair...beltronics do it these today for me...the cecksum was ok...if not,you can do it with programs like AEM...regards...if i was useful,press thanks botton please
    • Show your signature
  6. #36
    Jun 2010
    You are all the time useful thxxx alot tomorow will tray thxxx u are the best
  7. The Following User Says Thank You to milanocito For This Useful Post:
    betrescudan (12th July, 2014)
  8. #37
    Mar 2014
    Quote Originally Posted by milanocito View Post
    Better is safe tuning like is betrescudan make, than someone make you killer and rocket of car and you say, wow car is rocket, and after 2 month you will put on ebay "I buy motor"
  9. The Following User Says Thank You to ecupro For This Useful Post:
  10. #38
    May 2010
    Absolute rubbish that you can get 340hp on a std engine. Not a chance. I've spent thousands of hours on these engines, tuning them to over 700bhp on E85 but 340 from the std engine is one happy dyno.
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
  11. #39
    Oct 2012
    maybe with the help of Coyote Runner....bep,bep....from >Disney channel...........
  12. #40
    Jun 2010
    My car must do 100 in normal mode in 7 sec why now 12 sec
    I will remove driveshift to have good acceleration from stop
  13. #41
    Oct 2012
    milanocito...i made for you another map more sport if you want to test...waiting your response
  14. #42
    Jun 2010
    I.m intersting in good accelrration from stop
  15. #43
    Oct 2012
    ok ...wait 10 min...
  16. #44
    DK Veteran ZIZZOU's Avatar
    Dec 2011
    to get this you have to increase torque limiter for 1st and 2nd speed of gearbox, but there is a risk
    BOSCH FWA4630 @ BOSCH WBE4430 @ BOSCH TCE 4425 @ BOSCH ACS650
    BOSCH VLE2140 @ BOSCH KTS550
    PSA XS EVOL @ VAS @ MPPS @ MAGpro2 @ WILLEM @ UPA usb @ T300 @ AUTOCOM
    THE BEST SERVICE
  17. #45
    Oct 2012
    here is mod 2 a6...test and report please
